Distortion even at low levels.......
PMST
Post: # 64278Unread post PMST
Wed Feb 28, 2024 6:20 am
I have two VR heads, each head has been cutting around 200 to 300 discs each, per month for about 3 years.
In the past days, both heads are getting some nasty distortion, sibilance in particular, but even well below 0dbu at 45rpm which i have never encountered before. I've tested the heads, both read 4ohms on either side. That seems normal. I've changed amps, cables, swapped heads, diamonds and so on. I checked the fuses, they are reading low, but all exactly the same, across each lathe.
Has anyone else experienced this? I am wondering if it Is just the heads being worked too hard and having coil issues even with the ohms are reading correctly? Or could this be something else entirely?
Discomo
Re: Distortion even at low levels.......
Post: # 64282Unread post Discomo
Wed Feb 28, 2024 11:53 am
Have you checked your d/a converter? I had a clock problem once. It caused sibilance and clicking problems. Somehow the clock at my software didn’t correspond with my converter. Maybe something got reset after a software update. Once I made sure everything was running on the same clock the issue was gone.
PMST
Post: # 64287Unread post PMST
Thu Feb 29, 2024 7:47 am
Yeah i've swapped the players out and tried different sources, still the same.
I'm thinking it is just a send to Souri job, i cut a lot of discs, and have to cut loud so assuming at this point it is just wear and tear.
Discomo
Post: # 64289Unread post Discomo
Thu Feb 29, 2024 12:19 pm
I didn’t even know it’s possible that the coils can erode
leemichael
Post: # 64307Unread post leemichael
Fri Mar 01, 2024 5:18 pm
Post a clip, sounds like mechanical breakdown of one of the drivers from being pushed too hard for long periods.
Try cutting with one driver at a time momentarily.
drdub
Post: # 64352Unread post drdub
Tue Mar 12, 2024 8:11 am
Probably you can try to pan in software to left an right and see which side is the affected one.
*** www.drdub.com ***
Discomo
Post: # 64391Unread post Discomo
Sun Mar 17, 2024 2:42 am
Are the two VR’s connected to one source? I’d look there to start. The chances that both VR’s show exactly the same problem at the same moment seems unlikely to me
PMST
Post: # 64393Unread post PMST
Sun Mar 17, 2024 3:41 am
Thanks for all the feedback. The issue is now sorted. Strangely it was multiple diamonds causing this, i thought the odds of so many freshly 'resharpened' diamonds would never be the cause, low and behold, a set of new diamonds are used and order is restored.
Discomo
Post: # 64394Unread post Discomo
Sun Mar 17, 2024 7:53 am
Perfect! Glad it’s solved.
