12-inch Dinker/Label Punch
trendkiller
Post: # 60870Unread post trendkiller
Fri May 27, 2022 3:19 pm
Hello,
Does anyone know where, in the U.S., to get an automatic dinker to punch out labels on 12-inch records? P.M. me, if you prefer. Thank you for your help!
Lupu
Re: 12-inch Dinker/Label Punch
Post: # 60873Unread post Lupu
Sun May 29, 2022 4:17 am
RPA P-50
https://youtu.be/8qTd72niups https://youtu.be/djVxZDdfSqs
Not the most affordable solution but there you have it.
trendkiller
Post: # 60882Unread post trendkiller
Tue May 31, 2022 3:37 pm
Thank you! I wonder how difficult it would be to make one.
Rad
Post: # 60889Unread post Rad
Thu Jun 02, 2022 5:23 pm
Drill press, a hole saw, HSS is good enough, some 105-115mm in diameter and some pull down jig to keep the records in place so they don't fly away.
Ketaman
Post: # 60891Unread post Ketaman
Thu Jun 02, 2022 6:51 pm
We had one custom made by a local company, its not automatic but it works with both trimmed and untrimmed records.
https://speedex.com.au/index.php?route=product/category&path=275
trendkiller
Post: # 60895Unread post trendkiller
Fri Jun 03, 2022 11:55 am
Thank you, both, very much. Wouldn't a saw produce a lot of shavings and dust?
The Speedex is what we're looking for! Being in the U.S. though, shipping would be expensive. I'll look into it. Thank you, again!
Rad
Post: # 60965Unread post Rad
Mon Jun 20, 2022 8:39 am
i had good luck with this one:
https://www.wolfcraft.com/products/wolfcraft/en/EUR/Products/Machine-Accessories/Hole-Saws-Annular-Bits/Hole-Saws/Carbon-Steel-Hole-Saws/Carbon-Steel-Hole-Saw%2C-%C3%98-74---127-mm/p/P_5969
Yup.. Dust maybe (it shouldnt), shavings for sure... The hole saw needs to be the kind for cutting plastics anyway, so the shavings will be quite big and clean. You need to do the dirty deed away from the process anyway. The grinder itself will generate a lot more dusty junk anyway.
