Presto K8 Recording
Presto K8 Recording
I've been testing my K8 and it's been going well but the vocals are coming out all garbled. also the playback is very soft even with the recording volume turned all the way up during recording. Any ideas what could be causing this??
Re: Presto K8 Recording
mono or stereo head?
I use a k8. Sometimes that's just the way it goes. Having an inline multiple band (7+) eq goes a long way. Are you using the amplifier that's in there? It is designed to match the presto heads. I am experimenting with different amps to power the presto head. It is an old one and im pretty sure it is a J series head at 4 Ωs. MOST IMPORTANT THING use .5 v quick blowing fuse even with the onboard amp. i have blown so many of these funking fuses. Slight feedback on a line can get real ugly real quick. Especially if you are recording "harsh noise" or "experimental doomcore folk-metal". Which i hope you are.
Side note a: no way this is stereo.
Side note b: using a 300Ω matching transformer i can now play xbox on my 1950s circle-screen bakelite black and white televition. Every gamer on this forum should follow suit. You wont be disappointed
I am using the amp that's built into the machine. I just bought a good cutting needle and I'm hoping that that maybe solves some of my problems. The weirdest thing is Ill do a test cut that sounds fantastic, I wont adjust any settings, then when I go to do another take its all jacked up. Have you had this happen to you?
I guess make sure your swarf isnt bunching up on the needle? Is your vu meter reacting normally?
- tapesandtubes
A couple of things come to mind...
-Clean the armature
-Replace the tubes
-Clean the armature
-Replace the tubes
Presto K8 | 6N
Are you embossing or cutting lacquer? If embossing, you are going to lose 30+ of volume because of the hardness of the plastic and those presto 5c heads that came with most k8s weren't very hot to begin with and once you add on 80 years of godknowswhat abuse and disuse, you are not going to get loud cuts regardless.
My k8 hauls ass. Regularly cutting hot loud 45s with straight eq to beat most Hilltop pressings. But ive been hemming and hawing over this k8 for five years and learned a few things the hard way
How are you cutting 45rpm on a k8?
I record to really fast analog tape with a potentiometer on the tape speed. Then when i cut to disk im running the tape at a lower speed that's marked with a pen by the pot. It's kind of tricky to get the exact speed but there is a fifth note harmony that happens when you get the speed right. So at 33 rpm its all slow and stuff so if you can bring out bright highs on that then when you play it back at 45 rpm often sounds way better than the original tape recording. Which i find odd. almost like the setup is just filling in all the blanks for you. as if cutting to disk wasnt spooky enough already. But this only really happens when i have musicians come to my studio and record to master tape. Otherwise i just do 33. I think the beatles did some crap like this half speed mastering or whatever its kind of like that. Hope that helps. Screw the impossible to find k series 45 adapter. So basically im really pushing the boundaries of what you can do with the k series. Also cutting leadouts and locks by hand. No microscopes, only handheld vacuum nozzle. Ive basically known this was my calling for as long as i can remember. Reading oliver reads recorded sound book was like "well duh!" 800 pages of tellin me crap i already know. Sorry oliver, it is truly a great source. Me n a friend are experimenting transmitting sound via light waves like the old theater reels with some startling and spooky results. Btw mike i ran into a friend who said he rolled with your crew in like arizona or something. Carey mann from eugene. Says hi. Hope this was at least helpful for someone cheers yall.
Also i hear That the original IS THIS REAL? By the wipers was MASTERED on a k series
- grooveguy
Regarding your K8, that is the exact machine we had at our high school. I don't know when they got it, but probably some time in the 1940s. By the time I got there in the late 1950s, it hadn't been used in years, because the Radio Arts Department had gone over to tape as quickly as they could. (Webster Electric 'Ekotape' followed by an Ampex 600.) Being a disc-recording nut already for a good number of years, I latched onto the school's K8 and tried to make some records for use by the girls' PE department. By that time the machine was probably still less than 20 years old, but recordings were horrible. Very pronounced resonances in the upper-midrange and no bottom-end. The amplifier sounded fine (push-pull 45s, if memory serves), so I figured that whatever damping material Presto used in the head had dried out. Maybe that's your problem too. I still have a Presto 1D head, also dating to the 1940s, which sounds as good today as it probably did when new. But on the "semi-pro" machines, perhaps Presto didn't take the same care. Either that or the K8 was stored in a bad environment all those years. Get someone who knows that head to give it a going-over.
Hey yall!
I got it all sorted out. The problem was with the cutting needle. I purchased the ruby tipped one from Apollo and it now cuts perfectly!
Thanks for responding!
