Voyager Golden Record
Post: # 19379Unread post Aussie0zborn
Thu Apr 26, 2012 7:53 am
Let's work this one out....
So it sounds like :
1. They cut a lacquer at the JVC Cutting Center. Why a Pyral brand lacquer? Because cutting and plating them was a dream.
2. They silvered and plated the lacquer at James G Lee Record Processing like most people did back then.
3. They made a number of copper mothers and gold-plated them.
4. Nothing to do with DMM.
But, why does the Wikipedia photo of this gold-plated disc show a bush ring surrounding the centre hole if its a metal mother rather than a vinyl pressing?
diamone
Post: # 20456Unread post diamone
Sun Jul 15, 2012 4:49 pm
greybeard wrote:Mossboss, what makes you think that they physically cut this copper record at 16 2/3 rpm?
Because in 1977 - actually 1976 when the discs were cut - CD-4 Quadraphonic was in the last vestiges of its' death throes.
CD-4 had to be cut half-speed so that the constant presence of the carrier wave would fry neither the head nor the electronics from trying to cut real-time.
So it makes total sense that they cut a 16 2/3 RPM record real-time at the JVC Cutting Center - especially if it was a CBS contract, being some of the last of the CBS MasterSound LPs were cut there as well.
Their other choices at that time would have been Nautilus and Mobile Fidelity.
greybeard
Post: # 20476Unread post greybeard
Tue Jul 17, 2012 3:17 pm
----- well I was rather questioning the idea that the cut was directly on copper, not the speed as such. I do not know quite enough about DMM, but obviously 33 1/3 rpm and 45 rpm are sufficient to maintain the chatter at 70 kHz for the vertical vibration, but I have not read anywhere that "half-speed", i.e. 16 2/3, would do it. If it was directly on copper, what were the Pyrals needed for?
- my longest-lived thread! -
Post: # 20479Unread post mossboss
Tue Jul 17, 2012 4:00 pm
Not sure if this was covered it is a while that this thread had started
But how about this:
Is it possible that the cut on lacquer than the spattered a copper coating on it so as to preserve it from deterioration?
Again I am not sure if that was proposed or covered in the past If it has just ignore the input here of this -long lived thread- Hello George! you been silent for a while
By the way DMM would be a far better high freq cut than lacquer, just as lacquer is a better low freq medium to cut on than DMM
"The Vinyl Truth"
diamone
Post: # 20485Unread post diamone
Wed Jul 18, 2012 11:07 am
mossboss wrote:..DMM would be a far better high freq cut than lacquer, just as lacquer is a better low freq medium to cut on than DMM
Too bad they can't come up with a double-layer hybrid i.e like a FeCr cassette or Sony ElCaset that was out for three seconds in the 80's.
