Picnic Plate Cutters
piaptk
Post: # 10713Post piaptk
Sun Sep 26, 2010 9:24 pm
Picked up a stack of light green and they actuallyt sounded better than the ones from Safeway. And luckily they started selling 50 packs for $10 which is much better than the 20 packs for $7.99. I must have tried them out back before I knew what I was doing. Thanks for the tip.
Have you ever tried the Gold plates??
Jccc
Post: # 10819Post Jccc
Tue Oct 05, 2010 11:55 am
Does anyone know how to insert audio into a message/ post? I wanna post a example of of a few of my cuts that i did on some plates.
[/img]
piaptk
Post: # 10828Post piaptk
Tue Oct 05, 2010 5:41 pm
Jccc wrote:Does anyone know how to insert audio into a message/ post? I wanna post a example of of a few of my cuts that i did on some plates.
[/img]
You would just have to insert a link to the download file.
Jccc
Post: # 10829Post Jccc
Wed Oct 06, 2010 1:13 am
Here is a link to some of my lathe cuts that were cut on picnic plates
http://soundcloud.com/10shun-tenshun/03-03-strangled
http://soundcloud.com/10shun-tenshun/04-04-scabz
both were cut on a Presto 6n with a Audax R H5 cutting head with no heat.
I also have a track on there that was cut on a Apollo Audio disc 10" with the same set up. the Apollo disc transfers sound so much better with no surface noise.
piaptk
Post: # 10832Post piaptk
Wed Oct 06, 2010 9:42 am
Sounds really good... a little better than my own cuts even... I need to try transferring some of my cuts over to see what they sound like digitally. what kind of plates are you using? Where do you get them? Using Apollo long shank styli or old sapphires?
aaron
Post: # 10833Post aaron
Wed Oct 06, 2010 10:16 am
That's a TON less noise than I get with a long shank sapphire... but I'm using junkier plates. I plan on getting some from Party City this weekend, and I'll post some results as well.
Does any one know how harsh these plates are on a playback needle?
piaptk
Post: # 10835Post piaptk
Wed Oct 06, 2010 11:18 am
aaron wrote:That's a TON less noise than I get with a long shank sapphire... but I'm using junkier plates. I plan on getting some from Party City this weekend, and I'll post some results as well.
they are generally pretty easy on needles, but I have ruined three needles on standard cutting (not counting drops, etc) after about 1000 plates.
Jccc
Post: # 10836Post Jccc
Wed Oct 06, 2010 12:18 pm
Thank you for the feedback.
As for the cutting needle i am using a long shank sapphire. I got lucky when i bought the lathe because the person included a bunch of needles so im good to go for a while.
The sound is running through a Akai EA-A7 Equalizer and then through a Pyramid pa800x amp.
The plates i am using are red picnic plates from Ralphs grocery they like $6.00 for a pack of 50.
Jccc
Post: # 10840Post Jccc
Wed Oct 06, 2010 2:53 pm
here is the presto at work cutting a plate
aaron
Post: # 10841Post aaron
Wed Oct 06, 2010 3:13 pm
So you tilt the head back a little bit from the looks of it?
Jccc
Post: # 10842Post Jccc
Wed Oct 06, 2010 4:06 pm
yeah i have it tilted back like 5 degrees or so. As it says in the presto manual. The same angle works for cutting on acetates also.
Angus McCarthy
Post: # 10865Post Angus McCarthy
Sat Oct 09, 2010 10:55 am
Jccc wrote:Here is a link to some of my lathe cuts that were cut on picnic plates
I would love to hear a side by side with the original audio, just to see how much of that gritty compression and distortion is a result of the cut.
Jccc
Post: # 10873Post Jccc
Sun Oct 10, 2010 11:06 pm
Alot of my music is already kind of distorted and gritty . The lathe just sort of compresses the sound and makes it sound like it was recorded on cassette.
Thats one reason why i love these lathe cutters.
Jccc
Post: # 11864Post Jccc
Mon Dec 20, 2010 6:47 pm
Here is a link to a video i got of some picnic plate cutting action
http://shootyourfuckingheadoff.tumblr.com/post/2391357409
