Question for anyone with a VR T560 who uses a 1200/1210
status66uk
Post: # 51752Unread post status66uk
Sat Nov 17, 2018 7:38 pm
Im looking at trying to contact souri to buy a VR, After reading lots of varying opinions im not sure if i could get cuts without wow and flutter on a VR using a 1200/1210, Is anyone who uses souris standard set up (ie without the heavy platter and motor) able to cut consistantly without wow/pitch fluctuation using a 1200/1210?
Ive heard a lot of VR cuts and have always been happy with the general audio quality but some have had pitch variation, particularly on the outer areas of a 12" disc.
Really interested in your opinions before i take the plunge, if im successful Should i try to find an SP10 to use with it or technically is it possible to stick with the 1200 if i take in enough knowledge at the training course?
Re: Question for anyone with a VR T560 who uses a 1200/1210
Post: # 51772Unread post tragwag
Mon Nov 19, 2018 4:38 pm
I used a 1210 for the first few months, it was passable for 7" but never for 12" especially towards the outer edge like you mentioned.
I upgraded to a SP10, and SP15 respectively, and haven't looked back
e3sa934
Post: # 51774Unread post e3sa934
Mon Nov 19, 2018 5:58 pm
I've got a standard set-up with a 1210: I've been cutting 7s and 12s, and have only encountered wow & flutter on a 12" outer edge when I'd got the cutting stylus too 'heavy'. The 1210 I'm using is in decent shape, with new main bearing, which I expect helps.
TheCrates
Post: # 51788Unread post TheCrates
Wed Nov 21, 2018 11:32 am
3x SP10 !
Discomo
Post: # 51819Unread post Discomo
Sun Nov 25, 2018 2:34 pm
An additional question- are there any adjustments you need to make? (for instance height of the SP10)
And how is it done?
Post: # 51830Unread post tragwag
Tue Nov 27, 2018 5:08 pm
I just measured very amateur-ly with a ruler, where the 1200 sat when it was mounted in the feet.
So I matched the center of the SP10 with the center of the 1200.
The SP10 took one little 12" cardboard spacer underneath it for height, my sp15 took three added pads for height.
that's all though!
MEGAMIKE
Post: # 51833Unread post MEGAMIKE
Tue Nov 27, 2018 9:39 pm
Hi. To minimise wow and flutter on a 1200 I made a 4 mm brass 13inch plate . The
Difference was amazing I also never cut at the edge ,always 1 inch lead in before start..
Discomo
Post: # 51850Unread post Discomo
Sat Dec 01, 2018 3:46 am
tragwag wrote:I just measured very amateur-ly with a ruler, where the 1200 sat when it was mounted in the feet.
that's all though!
Many thanks! That's good news it's so simple! :)
fredbissnette
Post: # 52603Unread post fredbissnette
Sun Mar 17, 2019 7:02 pm
ill second using an sp10mk2 they can still be had at some radio stations and if you cant find these a gates or mcurdy are the answer
