ebay: Fairchild cutting stylii
fusionkid
Post: # 13921Unread post fusionkid
Thu Mar 31, 2011 3:30 am
greybeard
Post: # 13924Unread post greybeard
Thu Mar 31, 2011 4:56 am
There need not be any relationship at all between the tin and the stylii. The tin is interesting, because it says "With 4 deg Offset Flat". This shows that the stylii that were originally in the tin were made for cutting equipment without suction: the swarf was thrown to the side, most likely towards the centre where a brush on the nut collected it.
This fixed offset was the equivalent of rotating the cutting stylus in its holder. This means that the signal in one flank of the groove precedes that in the other, and it means that ideally, if you use an elliptical stylus for reproduction, that also should be rotated in the cantilever. You may use stereo reproduction with a conventional elliptical stylus, but you cannot use simple adding, but need to shift one channel in time, and variable at that.
