Do They Still Make Record Presses???? YES!!!
Vinyl Record press at Home
Post: # 5387Unread post mossboss
Wed Jun 10, 2009 7:09 am
dietrich10 wrote:Can it run without massive boiler and water system?
I still dream of a press in the corner of basement or garage without the town getting on me...
Don't know about dreaming, Andyb has it in his home Check out his video clip Simple effective setup Did not see any noise abbatement materials on the walls either May be he has deaf neighbours Or very tolerating ones It is there though in a little room in an appartement
Re: Vinyl Record press at Home
Post: # 5388Unread post Aussie0zborn
Wed Jun 10, 2009 8:05 am
mossboss wrote: It is there though in a little room in an apartment
True... with a water cooler in the back yard. Somewhere there will also be a boiler. https://lathetrolls.com/viewtopic.php?t=1075&mforum=lathetrolls
Record press
Post: # 5420Unread post mossboss
Sat Jun 13, 2009 11:53 pm
Aussie0zborn wrote:The cost of this is less than USD $50,000-00. Manufactured as a custom order with the appropriate hydraulics and control, you can realise a cycle time of 15 seconds. This could be a better option than restoring an old machine that is heavily worn.
No doubt it is a better option However you would still have a manual machine as well as the additional cost's involved in setting up a plant How about the following items which are deemed necessary for a plant:
Another $10K for the ballance of the installation? delivery, installation, steam, water, plumbing, electrical work switchboards air lines lighting
Another $20K for Dies just one set of each 7" 10" 12" with their associated holding down plates clamps centre pins or a dieset for each one of them
Moulds are $2 K a side $4 K a pair = $12 K, diesets are $2.5 K each x 3 = $7.5 K
Another $15 K for finishing centering, punching, forming gear for the plates
Another $10 K for auxillaries little fork lift pallett jack Granulator label punch out machine Air compressor Rack space and a few little bits and pieces
May be another $5 K for spares sitting on the rack
Now we are getting there You can look forward to start pressing Around $100 K you are in Allow about $15 K for the hidden lessons You are a vinyl record presssing shop in with one machine. So here is what to look forward to: Frequent die changes frequent plate changes customer expectations which sometimes defy logic But you can press records Please allow about a $100 bill per 100 records as well, you will burn that in the begining or just walk down the corner and give these $100 bills away to passers by They will be thankfull for your generosity pray for you and your soul wishing you everlasting health long life and prosperity You wont get that setting up a pressing shop for any size record you press from any customer You will get praises though No doubt and you can be a proud man and part of the trend in the ever diminishing pool of vinyl record pressing plants
