stylus heating question (plastic)
- Dub Studio
Re: stylus heating question (plastic)
Not exactly. OK so the method I use is as follows:
1) cut off a couple of inches of wire (length = 2 x distance of stylus from binding posts, plus 8 x windings, plus a little spare at each end to hold on to)
2) mount the stylus in the head
3) tie one end of the wire to a binding post, leave a little hanging off the post as you will probably need this to retie it if you want to change stylus at any point
4) hold the wire taut, and start winding. With each winding ensure the wire is aligned nicely by pushing it down towards the hilt (you need finger nails for this, not good if you have fingers like sausages). Make sure the wires don't overlap (or wind over eachother). Never let go of the wire or slacken it off too much while you are winding, you will lose the neat winding and possibly damage the stylus tip if the wire recoils off the end.
5) once you have the sufficient number of windings (I stick to 8, but it depends on your set up and stylus length), tie the other end off on the other binding post, again leaving a little spare on the end.
6) once you have ensured the coil is in place, and holding firm, you can slacken the wires off from the binding posts by a mm or so. To do this, simply loosen the binding post a little, and push the wire sideways until you feel a little of the spare wire (see point nymber 3) pulling towards the binding post. You are going for a slight bowing of the wire, no craziness. This will give free movement, but also hold the coil.
Just to reiterate, if you do this properly, there is no need for glue. All cutting heads are designed such that the binding posts are set higher than the stylus, so the wire will always pull upwards, holding the coil in place on one end (and the hilt holds it in place on the other). Plus the wire has a certain amount of malleabilty, and will form around the stone.
Will give it a try
Hi Sorry if a bit late to the party: I cut with myshank diamond and blanks. I don't go over 30 degrees as the swarf goes sticky. Usually about 27 and with stylus heat up to 0.3 A. Especially as the stylus wears down a bit. As start getting a bit of surface noise.
I have found it a problem with swarf sticking to the disc and up the tube in the past so it has been a balancing act to get it right. Getting the stylus weight right has also been a factor.
Best
Nik
Best
Nik
Nik Clifford
Pearl Home Records
Pearl Home Records
- farmersplow
Hi, greetings to Bristol and thanks for the explanations!Dub Studio wrote: ↑Thu Jun 30, 2022 8:03 amNot exactly. OK so the method I use is as follows:
I am planning to fit my diamond with a NiChrome heating wire. I understand that it should be a thin NiChrome wire of about 0.1mm - about 8 turns. I have three questions about this:
1: Does the 8 turns also apply to diamond gravers?
2: Do you use an insulated NiChrom wire? Because if I wind it uninsulated, the current will probably no longer run through the coil but directly from the input to the output. And if insulated, then I have only found 0.15mm NiChrom wire and with insulation it has a diameter of 0.3mm. With 8 windings this means a length of 2.4mm! That is longer than the available space on the diamond. What do I understand wrong?
3. if I want to glue, which glue (drop of glue) should be used? I first thought of the dentist technique and UV-curing adhesives. Alternatively also Epoxy2K. Has anyone had any experience with this?
Greetings from Austria
Thomas
- Dub Studio
Any time!farmersplow wrote: ↑Thu May 02, 2024 10:51 amHi, greetings to Bristol and thanks for the explanations!Dub Studio wrote: ↑Thu Jun 30, 2022 8:03 amNot exactly. OK so the method I use is as follows:
OK so:farmersplow wrote: ↑Thu May 02, 2024 10:51 amI am planning to fit my diamond with a NiChrome heating wire. I understand that it should be a thin NiChrome wire of about 0.1mm - about 8 turns. I have three questions about this:
Thomas
1) Yes, it works for diamond and sapphire, I started winding my own heating coils when I broke one and couldn't get a replacement for a diamond. I then started replacing them routinely if they were wound too close to the tip, for example, or I just wanted to give the stylus a good clean.
2) Good question, I forget, it was a long time ago I bought a few reels. I don't think it's insulated because it would probably stop the conduction of heat to the stylus, plus the insulation might end up melting anyway. I guess that as long as the winding starts at one end and doesn't overlap it should conduct nicely through the coil. The electricity will mostly take the path of least resistance, and even if there is a bit of shorting, it will just create heat, which is what you want. It is very important not to let the wires touch once they leave the stylus tho... that will cause a massive short and prevent any heat reaching the stylus. Having said that, exercise caution and try both if not sure.
3) Sorry I can't help with that one, I find glue is just annoying, what is the use case for it? I imagine you want the following criteria:
- conduct heat but not electricity
- doesn't melt / burn
- easy to remove
- Dub Studio
Here is one I made earlier... 6 or 7 turns on that one, but you get the idea: https://www.instagram.com/dubstudio/p/CEb48Z1BhRS
- farmersplow
Thank you for your quick reply. The FEP insulation can withstand at least 250°C, which is sufficient for the stylus. In your picture with wire winding, the coil is largely without contact. But if they were touching (without insulation) there would probably be a powerful short circuit with temperatures too high for the diamond at certain points. But I can probably hear the grass growing! Your practice shows that it works, even if it is not logical.
The purpose of the bonding is to prevent the wire from slipping, even if it is not "tensioned" on the terminals. The adhesive is thermally conductive and the wire is in contact with the diamond. This should not be a problem. Loosening the adhesive, on the other hand, could be difficult.
Removing and installing the diamond is also easier with the wire.
I will get myself a 0.1 mm NiChrom wire and test the whole thing for a short circuit. Then I'll get back to you.
Thanks again
Thomas
Thanks again
Thomas
- Dub Studio
I guess I always assumed that the elecricity would take the path of least resistance... and that the minimal surface contact between windings of the same wire would ultimately be less conductive than the full gauge of the wire itself. After all, the wire is already kind of short circuiting, so in order to short circuit a short circuit, you need something more conductive than the circuit itself?
If the circuit was doing some other work (apart from just heating up), like driving a motor for example, then yes, perhaps it would be more likely to short the circuit in a meaningful way (because it is a much easier path than going through all the windings of the motor) but jumping from one winding to the next does not seem to me to be in the electrons' interest.
I don't know, electronics is not my forte so this is just my intuitive understanding of the matter. Perhaps you are right and the only thing stopping it from shorting is the spring effect of the coiled wire. Happy to be proven wrong there
- farmersplow
Stylus heating wire
Now that the 0.1mm heating wire has finally arrived, I can start the experiment.
The question is, will the wire cause a short circuit if it is wound tightly and touches itself?
So I wound the wire onto a rod (non-conductive) with 6 turns.
The wire moved apart like a spring.
The resistance measurement showed 15.3 Ohm (including the leads). It should be noted that the rod is much thicker than a stylus. The stylus has a circumference of about 2.8 mm and my rod has a circumference of about 8.2 mm. The resistance value is therefore not comparable with the ‘original’ resistance value of the cutting stylus. But for the measurement, I only want to compare whether the resistance value changes when the coil winding touches.
In the next step, I pressed the winding together so that the wires touch each other.
The resistance measurement showed 12.2 Ohm. (Including the leads).
The current flow changes when the wires touch and a kind of short circuit occurs.
Nevertheless, I have to put the result into perspective. It was very difficult to keep the wires together. Even if you wind the wire under high tension, the spring effect will keep moving the wire apart like a spring. So it will be almost impossible to create a short circuit!
To Dub Studio: From an electronics point of view, I can confirm that the current takes the path of least resistance. If the surface is not corroded so that it has an insulating effect, then the current will run over the surface instead of through the wire in any case. It therefore depends on the insulating effect of the surface and the surface that is in contact. So when the wire is wound up (nicely next to each other and not on top of each other), there is no large contact surface because the spring effect prevents a tight fit.
In any case, I'm reassured that I don't have to worry if I do it the way DubStudio suggested.
DubStudio - Thanks again!
Thomas
Thomas
