Grease and Lubrication Question
weeweehourEmery
Post: # 63264Unread post weeweehourEmery
Thu Aug 24, 2023 7:44 am
Hi there!
I'm wanting to reapply grease underneath the platter of my Presto 6N lathe. What type of grease should i use for this? Are there any other parts of the lathe I should use this grease on?
I deeply appreciate everyones help and this website!
- Emery
mushroomjesus
Re: Grease and Lubrication Question
Post: # 63870Unread post mushroomjesus
Sat Dec 30, 2023 12:58 pm
Sad no one replied to this. I don’t have a presto but I use gun oil on my turn screw. Thinking about getting a presto you can always reach out to Mike Dixon.
boogievan
Post: # 63872Unread post boogievan
Sun Dec 31, 2023 1:35 pm
Haven't seen a Presto, but the L. J. Scully platter has an oil well, and the dip stick is parked inside the A-table. It takes SAE 10 (eq. to ISO32) motor oil. I've been using SAE 10 pneumatic lubricating oil, fwiw.
The feedscrew takes no lube on its thread, but occasionally, oil should be added to the pinion bearing via a very small hole on the screw's hub (on the left-hand side) that's only visible once each rotation.
Fwiw, I noticed this thread on L. T. regarding the Presto 6N:
https://www.lathetrolls.com/viewtopic.php?t=5278
The OP, who has a 6D, states: "The 6N manual recommends 3 in 1 oil."
3-in-1 is supposedly SAE 20 weight. Replies suggest using sewing machine oil, instead.
Great Grandpa used to say, "It's the wheel that squeaks that gets the grease."
