New Embossing Stylus!
EposLab
Re: New Embossing Stylus!
Post: # 57221Unread post EposLab
Tue Nov 17, 2020 11:52 pm
EposLab wrote:
Tue Nov 17, 2020 1:42 am
increase of background noise on the inner groove
Sorry , i ment the "inner side of the groove"
http:\\www.eposlab.gr
info@eposlab.gr
EposLab
Post: # 58301Unread post EposLab
Sun Apr 11, 2021 6:13 am
Thefollowing is a sample from a recent Test Cut i did!
Please notethe frequency response above 10kHz!
*I have to notice that the overall performance is EQ optimized , i mean i fixed the resonant frequencies about 400-500 kHz and emphasize the 10-12kHz , 16kHz is 0dB and 20kHz is -12dB!
info@eposlab.gr
grooveguy
Post: # 58319Unread post grooveguy
Mon Apr 12, 2021 4:25 pm
Hey, Tasos, what are we listening to on the audio portion of that YouTube video? Wasn't sure if it was music or an old Internet dial-up connection sound.
EposLab
Post: # 58320Unread post EposLab
Mon Apr 12, 2021 4:30 pm
Thats a part of the track with lots if high frequencies!
Sorry what you hear the piezo-speaker of my vintage oqo01 :-)
If you like the real sample of the track i can send you the .wav file!
info@eposlab.gr
grooveguy
Post: # 58321Unread post grooveguy
Mon Apr 12, 2021 4:40 pm
Yes, indeed, I would love to hear it! Can you put it up somewhere and link it for the group?
Angus McCarthy
Post: # 58343Unread post Angus McCarthy
Wed Apr 14, 2021 11:13 am
Great work, Tasos! Have you had a chance to experiment with having a sapphire cut to your new triangle shape? I have a few worn-out cutting sapphires and I am considering having a local jeweler I know try to re-shape one into a cone and one into your design so I can compare the two.
EposLab
Post: # 58344Unread post EposLab
Wed Apr 14, 2021 11:25 am
Not really but i will maybe try when i have time. But I am really curious about the results! Please post here if you're going to try :-)
info@eposlab.gr
EposLab
Post: # 58425Unread post EposLab
Sun Apr 25, 2021 8:11 am
If anyone is interested to try my stylus please keep an eye at "classified section & tip-offs" section as i will soon uplosd ut for sale!
Thanks
Tasos
Epos Laboratory
info@eposlab.gr
grooveguy
Post: # 58426Unread post grooveguy
Sun Apr 25, 2021 11:01 am
Hmmm. Just checked the Forum Index and couldn't find a Classified section. Used to be one, I thought.
SONARC
Post: # 58428Unread post SONARC
Sun Apr 25, 2021 11:26 am
Hey there - I noticed that a bit earlier today, and I've been seeing some other odd behavior as well (post dates changing, threads appearing intermittently, etc), but I think it probably has to do with the site issues Steve E. mentioned here:
https://www.lathetrolls.com/viewtopic.php?f=17&t=9131
EposLab
Post: # 58433Unread post EposLab
Sun Apr 25, 2021 4:37 pm
Check here: https://www.lathetrolls.com/viewtopic.php?f=4&t=9174
info@eposlab.gr
EposLab
Post: # 60773Unread post EposLab
Thu May 12, 2022 2:36 am
Happy to announce you that I done the R&D and feel my stylus is ready :-)
Made to order so please contact me to "info@eposlab.gr" for more info!
Some trolls already use it so feel free to leave you feedback at the Classified section (https://www.lathetrolls.com/viewtopic.php?f=4&t=9174)!
info@eposlab.gr
discosdecorte
Post: # 60780Unread post discosdecorte
Sat May 14, 2022 10:29 am
Beautiful work, man! Congrats! 🙌🏼
farmersplow
Post: # 60781Unread post farmersplow
Sat May 14, 2022 12:35 pm
Great work! Also from my side congrats! Only the length specification on the specification sheet with 1.8mm cannot be correct.
grooveguy
Post: # 60784Unread post grooveguy
Sat May 14, 2022 1:21 pm
Good catch, FP! 18mm is more like it... or, if you're anti-metric, 5/8 to 3/4 inch.
EposLab
Post: # 60785Unread post EposLab
Sat May 14, 2022 1:38 pm
I always had the feeling that something was not right on the spec sheet, now that you told me I see what was and fixed it already :-)
Thanks
Tasos
info@eposlab.gr
grooveguy
Post: # 60786Unread post grooveguy
Sat May 14, 2022 1:50 pm
Very good, Tasos. While you're at it, you also might consider eliminating the spaces in your email address at the bottom. I'm sure that most seasoned email users know that the @ is not separated fore and aft, but making that footer look more like the one in your icon would be good, I think. I know, it's nice to have that line the same length as your business name, but centered would look good too.
EposLab
Post: # 60787Unread post EposLab
Sat May 14, 2022 3:21 pm
I know seems to have lot of space but the truth is that this card is actually small and leaving space between make it more visible and easy to read. If I make it close I believe they'll be confused.. but thanks anyway :-)
info@eposlab.gr
meltingpotsound
Post: # 61413Unread post meltingpotsound
Wed Aug 31, 2022 10:41 pm
I've been manufacturing for 6 years the sapphire embossing styli at "https://nylathecuts.com/" for Mike Dixon which is available exclusively only through his website "https://www.recordlatheparts.com/products/sapphire-embossing-cones" if you would like to learn more, watch actual use on my YouTube channel "https://www.youtube.com/watch?v=Bh97II404kw"
EposLab
Post: # 61446Unread post EposLab
Fri Sep 09, 2022 8:19 am
I have examine & emboss many hours using both Solid Tungsten cone and Sapphire cone . Sapphire cone is a big upgrade over the solid Tangsten cone in terms of frequency response and clarity due to its lighter total mass but also higher noise and static noise due to insolation properties of the stone.
Making a stylus with aluminium shank and tungsten cone tip , in equal mass to the sapphire , solves the static noise issue and actually has an even more natural frequency response!
Second issue is the tip design. Using an advanced Triangle tip instead of Cone , you'll notice more extended frequency response on both lows & highs and more clarity. That's something I have experiment & experience with all these by time.
The last months i did experiment with different angles of the triangle tip and finally ended on 100° groove angle which I find to be the more optimum in terms of frequency response , clarity and noise floor. Lifetime I have tried myself is 30hours , frequency response remains at 95% with no noticable distortion.
All tests done on my environment with average room temp of 22°C and humidity between 50-55%.
All blank discs prepared using light fluid, no heat on the blanks or the stylus was applied.
Tasos
Epos
info@eposlab.gr
