new guy here a few questions
- fredbissnette
Re: new guy here a few questions
this is by far the loudest cut ive been able to get onto lexan
https://www.mediafire.com/?ksh2qiaa457obfm
this is a test cut and not a cut for a client i do not bootleg audio en mass
- fredbissnette
more acid house goodness
love how this style of electronic sounds on lexan
https://www.youtube.com/watch?v=CUKQ4ioo54o&feature=youtu.be
- fredbissnette
https://vid.me/nOo4
https://www.youtube.com/watch?v=dBx6EfkDydU&feature=youtu.be
https://vid.me/Xnec
one off for my collection im not in the business of bootlegging
https://vid.me/Xnec
- fredbissnette
after doing a bunch of critical listening tests and a-b ing test cuts with originals i have found that i still have a bit of warble issues with the 1200 even after it has been modded for torque
its almost not detectable ona 45 but on a 10 inch the firsrt cm or so has a bit
i may look for a sp10 mk3
cheers
cheers
mk3 is one of the best ever made broadcasting turntables comes with technics sp-02 record lathe motor but too priceyfredbissnette wrote:after doing a bunch of critical listening tests and a-b ing test cuts with originals i have found that i still have a bit of warble issues with the 1200 even after it has been modded for torque
cheers
http://www.ebay.com/itm/Technics-SP-10-Mk3-Turntable-Complete-Power-Supply-Original-NICE-Condition-Rare-/371836570579?hash=item56932fcbd3:g:Z7wAAOSwM4xXYPXs
sp10 mk2 have 6 kg/cm torque it's a nice deck for cutting and embossing at half price
http://www.ebay.com/itm/Technics-SL-1000-MKII-Professional-Direct-Drive-Turntable-/301972543459?hash=item464ef757e3:g:ll0AAOSwvg9XT5gn
also the sp15 it costs between 400-700$ and have 3kg/cm torque it's good for cutting but i'm not sure for embossing
http://www.ebay.com/itm/Technics-Direct-Drive-Turntable-SP-15-with-toner-arm-base-and-cover-/201804807959?hash=item2efc80ff17:g:FnIAAOSw9GhYZtfl
- fredbissnette
you can hear the warble at the beginning of this 10 inch cut i did
i dont have this problem with 7 inch records
https://www.youtube.com/watch?v=Ux-zHr0mmw8&feature=youtu.be
- fredbissnette
an mk2 sp10 would work well i think
my opinion is if you are interesting only for embossing why don't you try a Numark TTX1 or Numark TT500 with 4.5kg/cm torque?
Their specifications gives 0.003 Wow&Flutter vs Technics sl1200 mk2 0.002,5 Wow and Flutter
http://www.ebay.com/itm/Numark-TT500-Professional-DJ-Turntable-with-dust-cover-/182436455096?hash=item2a7a0f62b8:g:A8YAAOSwNnRYjF2H
http://www.ebay.com/itm/numark-ttx-turntable/112287223904?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20131003132420%26meid%3Da63fe0531c7b45639acdf9bbedd208f0%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D182436455096
sold your Mk2 and give a try to Numark if you are not happy then go with sp10 mkiifredbissnette wrote:an mk2 sp10 would work well i think
- fredbissnette
Then go with sp10 for sure
fredbissnette wrote:i would want try one first
- fredbissnette
i have seen sp 10 go for about 1000 on ebay they are not too crazy expensive
Be careful do not buy the MK1 it have same torque as the SL-1200 MK2fredbissnette wrote:i have seen sp 10 go for about 1000 on ebay they are not too crazy expensive
https://www.vinylengine.com/library/technics/sp10.shtml
- fredbissnette
yes im aware of all the tork differences the mk1 is 1.3 the mk2 is 6 the mk3 is 16
my 1200 is at about 2.5 rt now
- fredbissnette
i have put my 1200 up on ebay and im gonna buy a ttx
4.7kg of torque should work
- fredbissnette
picking up a st150 tomorow
ill keep us posted
ill keep us posted
- fredbissnette
the hanpin oems dont work at all they have great starting torque and great acceleration but no real moving torque
i modded my 1200 to have a 68k resistace at r209
that works better than where i had it at 100 but i still have a warble
its on pronounced on music with sustained notes but its there
my audio is getting really good
im dead in the water until i find an sp10 2/3
did you had warble with stanton?fredbissnette wrote:the hanpin oems dont work at all they have great starting torque and great acceleration but no real moving torque
did you try to disable the pitch lock?
As far i know the stanton does not have the same quartz lock as Technics have.
how heavy your cutterhead is? my Fairchild weights 8.25 oz and i don't have any warble problem with stanton
could you upload a video with embossed music on stanton please?
- fredbissnette
i think it has to do with my needle im using a hyper sharpened tungsten and my cutter head is about 175 g
i need to be able to emboss 10''
i have tried a lot of dif setups
i know a sp10 is the answer
- fredbissnette
so now im on the hunt for a broadcast deck
called cbc and lots of radio stations
got some lines on asome gates decks
i have my lathe torn apart ready for retrofitting
lathe 4.o soon
lathe 4.o soon
- fredbissnette
i scored two mccurdy ch 12 turntable bases today
i will pick them up sat
i will post my progress on this
cheers
cheers
