Sillitoe Lathes
Sillitoe
SP10MKII Lathe
Post: # 33322Unread post Sillitoe
Wed Jan 28, 2015 11:44 am
This is made from a sliding compound mitre saw base and arm running on linear bearings.
The saw base (that houses the linear bearings) is mounted within the plinth and has thick felt on top of it. The TT is mounted on top of it via M5 threaded rods running the depth of the plinth, sandwiching the saw base and bearings very solidly and making it all perfectly square and level.
It is just a pwm controlled brushless dc motor turning a ball screw, I need to make a plate marked with LPI to be mounted behind the pointer knob.
The suspension box has an air dashpot a spring and a hard drive bearing.
I've been cutting with a homemade head but I don't yet have an amp with enough power, I'm planning on using Hypex Ncore 400 modules and Caruso.
I'm making another one of these with plans to use Ableton Max for Live, Maxuino and an Arduino as a pitch controller.
I've also made another lathe with an overhead similar to the T560, I'll post more here soon.
James
budharpey
Re: SP10MKII Lathe
Post: # 33325Unread post budharpey
Wed Jan 28, 2015 5:05 pm
beautiful build +1
MEGAMIKE
Re: SP10MKII Lathe
Post: # 33353Unread post MEGAMIKE
Fri Jan 30, 2015 4:44 am
Great work James..very jealous...hahahaha...
Re: SP10MKII Lathe
Post: # 33355Unread post tragwag
Fri Jan 30, 2015 3:40 pm
Nice!
How does the SP10 perform in terms of running torque?
any pitch variation on playback?
Sillitoe
Re: SP10MKII Lathe
Post: # 33356Unread post Sillitoe
Fri Jan 30, 2015 5:17 pm
Thanks guys!
I can't detect any pitch variation on playback via SL1200MKII , it seems very stable.
I made my experimental heads to weigh roughly the same as the 285gram aluminium Caruso.
So far I've been cutting with the steel triangles from Jerry both with and without heating lamps, I've played a bit with different head angles- the cuts don't sound great but the TT speed seems good.
I ordered my Caruso yesterday and I'm eager to see how the system performs with it!
Re: SP10MKII Lathe
Post: # 33357Unread post opcode66
Fri Jan 30, 2015 5:37 pm
If I recall correctly, they are 15 kg-cm for torque. That is quite a lot!
Sillitoe
Re: SP10MKII Lathe
Post: # 33358Unread post Sillitoe
Fri Jan 30, 2015 5:46 pm
That's the MKIII you're thinking of, the MKIIs are a mere 6kg-cm...
http://www.vinylengine.com/library/technics/sp10.shtml
Re: SP10MKII Lathe
Post: # 33359Unread post opcode66
Fri Jan 30, 2015 5:48 pm
I was reading MKIII for some reason.... Need to get my eyes checked.
Regardless, that is still 3 times more torque than a modified technics 1200
Re: SP10MKII Lathe
Post: # 33456Unread post tragwag
Tue Feb 03, 2015 2:15 pm
wow, excellent! Glad to hear it works for you, I'll be on the lookout for one of those to upgrade my VR setup.
Sillitoe
Re: SP10MKII Lathe
Post: # 33472Unread post Sillitoe
Wed Feb 04, 2015 1:06 pm
Here's another lathe I'm working on for my other SP10MKII.
The plinth and mechanics are from a huge NUR Tempo II billboard printer.
I was recently given a rare opportunity to scrap two massive printers for parts and this lathe just sort of came together, I have only needed to drill a few holes so far!
The pitch motor is in the mail and I need to build a suspension box.
Sillitoe
Re: SP10MKII Lathe
Post: # 33487Unread post Sillitoe
Wed Feb 04, 2015 7:22 pm
Here is a quick and dirty proof of concept for my pitch controller.
Track volume automating midi to control pulse width modulation for pitch motor.
Ableton- Max for Live- Maxuino-USB serial port- Arduino- electronic speed control- bldc motor...
https://www.youtube.com/watch?v=8c9aZbduexs&feature=youtu.be
This motor is a Maxon EC-Max with a reduction gear head.
You can still cut from PT and run Ableton via re-wire for preview.
Here's some tutorial videos- http://www.maxuino.org/video
Cheers.
ROLANDJAYS
Re: SP10MKII Lathe
Post: # 33489Unread post ROLANDJAYS
Wed Feb 04, 2015 8:21 pm
that's pretty dang cool..
dimi751
Re: SP10MKII Lathe
Post: # 33569Unread post dimi751
Sun Feb 08, 2015 9:20 pm
Nice work love the design on both lathes :D
Sillitoe
Re: SP10MKII Lathe
Post: # 33570Unread post Sillitoe
Mon Feb 09, 2015 2:30 am
Thanks fellas!
https://www.youtube.com/watch?v=LSENUgelA84&feature=youtu.be
This quick video is to show the pitch motor being controlled by midi clip envelopes.
I still need to sort out many aspects of this pitch controller.
At the moment I have to draw in the automation envelopes by hand.
I need to think of how to plot the clip envelopes in real time while accounting for volume, frequency, tt speed, running time etc etc etc.
Shouldn't be too hard... haha.
Mechanics.
Sillitoe
Re: SP10MKII Lathe
Post: # 33571Unread post Sillitoe
Mon Feb 09, 2015 3:18 am
Sillitoe
Re: SP10MKII Lathe
Post: # 33574Unread post Sillitoe
Mon Feb 09, 2015 10:16 am
I've just been successful in making the Maxuino midi clip follow the volume information from an audio clip in real time.
This means that the pulse width modulation going to the motor is driven directly by the changes in audio volume.
Great! It was easier than I thought it was going to be :D
I will post a video tomorrow night showing this but I still need to add all of the other parameters to make it work in a usable way.
But it will work!
I think this will eventually be a pretty creative tool to cut records like Lazaretto because you can draw in the pwm signals with the pencil tool too.
Still a long long way to go though.
ejemmons
Re: SP10MKII Lathe
Post: # 33576Unread post ejemmons
Mon Feb 09, 2015 2:01 pm
Two thumbs up from over here! Well done!
RA-1574E amps.
Re: SP10MKII Lathe
Post: # 33587Unread post opcode66
Tue Feb 10, 2015 5:20 am
Super work. Really nice.
Sillitoe
Re: SP10MKII Lathe
Post: # 33593Unread post Sillitoe
Tue Feb 10, 2015 10:08 am
Thanks guys, it means alot! :D
Here's a vid of volume driving the motor. Look at slider 9 in the maxuino patch at the bottom left of screen.
I'll show you how I achieved this sometime... I'm still figuring out how to implement the other factors properly.
This system will allow multiple lathes to run automatically from one arduino board.
Arduino Uno should be able to run 6 via pwm although I'm actually using servo mode in these tests.
I was going to use test tones for this demonstration but I noticed the serious lack of music from the Himalayas in this forum, specifically music from the Manipur Hills!
Sillitoe
Re: SP10MKII Lathe
Post: # 33594Unread post Sillitoe
Tue Feb 10, 2015 10:15 am
The second channel of audio isn't present in that previous video, it had the sound from the motor- something went wrong in the upload- just keep an eye on the pulleys and slider number 9.
Cheers.
