I recently grabbed an Audax H-4 head off ebay, since it was built for 8ohms I figured I could drive it with the amplifier in my K-8. Does someone have any technical info on this head? The only entry that comes up on Google is another post on the forums here asking for information as well!
Also any advice on how to disassemble it would be super, the dang thing seems riveted shut!
Does it look like a rivet from the front? If its the same as the RH5 it's not a rivet. The screw part is seal at the back with some sealant, it's easy enough to rewove with a flat head screw driver. Your screw part should be there.
Oh dear... I found the spot on the back and dug out the filler without destroying the label too badly, but upon trying the screw ...half the head snapped off. Now what?
That's a bit of a pickle right there. Going to need a screw removal set. The +&- cables are to the left and right of screw and bobbin is at the very bottom so you won't hit anything vital with screw removal if it goes wrong.
