Sound maximizer
Audiofiligram
Sound maximizer
Post: # 13490Unread post Audiofiligram
Fri Mar 18, 2011 4:39 pm
Hi Trolls ,
I was thinking about using a Sound maximizer Plug in From Universal Audio
to get more Loudness on Tracks , this tool give you the possibility to get
higher perceived loudness without influencing Dynamic Range of the Audio Material . The Plug ins adds harmonics to the original Signal , Specially
for high Frequencies it could be a Problem ? What do you think about it ?
Has somebody some experience ?
I´m using The VC 2000 Amp & SC 99 Cutterhead .
Thanx
gengy
Post: # 13492Unread post gengy
Fri Mar 18, 2011 6:07 pm
hi!
in my opinion any exiter could be a dangerous tool in cutting because if the source is not good (eq-dynamic,ecc) this effect may worsen the situation.
for high level cutting the exiter or harmonic effects are not the trick!
cheers
Alessandro Di Guglielmo
Mastering and Disk Cutting
Post: # 13493Unread post opcode66
Fri Mar 18, 2011 6:25 pm
Got to watch out when exciting the high end frequencies. That is how cutterheads get smoked. Most cutterheads have their resonant frequency in the high end... And, they do tend to naturally emphasize the high end.
A lot of people do banded compression and maximization. I would just be careful about the higher frequency bands.
You can also use stereo expansion to get more perceived volume.
JayDC
Post: # 13494Unread post JayDC
Fri Mar 18, 2011 6:27 pm
i would look into a multi-band compressor and limiter.. I use a good one by yamaha called final master was like 99 bucks or something.. I dunno if you can still get it though.. I love it,and everything i make runs through it.
Audiofiligram
Post: # 13495Unread post Audiofiligram
Fri Mar 18, 2011 7:27 pm
I heard limiting is not so good because this Processing
adds lot of high Frequences to the Audio Material,
that would mean more current to the cutterhead ,
Is it true ? what do you think ?
dietrich10
Post: # 13496Unread post dietrich10
Fri Mar 18, 2011 8:25 pm
You are better off with a chain of processing. An EQ, compressor/limiter and could incorporate a maximizer type plug or process if you can also EQ unwanted and dangerous frequencies out.
CONTROL and options are key. every track is different
cutting lacquers-vms70 system
JayDC
Post: # 13497Unread post JayDC
Fri Mar 18, 2011 9:13 pm
in my cutting chain i use 6 primary plugins..
I use a desser
then an EQ (which is set up with my tones)
RIAA
Another EQ I use to control my sound
high pass at 30hz lowpass at 10K
and a limiter to catch any overly loud hits
thats what goes to the cutter
now in my mastering chain for when i write/mix music
Desser
EQ
Final master
Limiter
Audiofiligram
Post: # 13510Unread post Audiofiligram
Sat Mar 19, 2011 3:40 pm
Thanks for The Input Trolls ...
Certainly the best thing to do would be to plug a Spectrometer between
amps an Cutterhead to control The Frquencies ....
Post: # 13512Unread post opcode66
Sat Mar 19, 2011 4:38 pm
I use both frequency analysis and spectral analysis to insure that the energy is in the frequency ranges I want.
dietrich10
Post: # 13514Unread post dietrich10
Sat Mar 19, 2011 4:46 pm
Ears still beat looking at frequencies.
I've seen guys push certain ranges just 'because' when no need for it. like a habit
Post: # 13515Unread post opcode66
Sat Mar 19, 2011 5:11 pm
Duh... My ears are always the judge and jury. Naturally.
Angus McCarthy
Post: # 13516Unread post Angus McCarthy
Sat Mar 19, 2011 5:39 pm
Audiofiligram wrote:Thanks for The Input Trolls ...
Probably not between. You want to keep that connection as clean as possible, you know. Somebody mentioned elsewhere on here about using the monitor output to drive a Spectrometer.
dietrich10
Post: # 13519Unread post dietrich10
Sat Mar 19, 2011 5:47 pm
opcode66 wrote:Duh... My ears are always the judge and jury. Naturally.
but you just said above you use the analyzers to check the 'energy' 8)
Post: # 13520Unread post opcode66
Sat Mar 19, 2011 6:14 pm
visual inspection != final determination
just one of many things I use to make good cuts...
i am a musician at heart though. so, my ear is what i rely on no matter what.
Audiofiligram
Post: # 13528Unread post Audiofiligram
Sat Mar 19, 2011 11:34 pm
I got the possibility to get the signal from the Cutterhead called
Feedback Output (There is an output on teh Amp)
Audiofiligram
Post: # 15398Unread post Audiofiligram
Sat Jun 18, 2011 11:51 am
Anibody have suggestion For Spectrum Analyzer Software ?
Post: # 15401Unread post opcode66
Sat Jun 18, 2011 3:11 pm
SpectraFoo
Nickou
Post: # 15411Unread post Nickou
Sun Jun 19, 2011 10:04 am
opcode66 wrote: Most cutterheads have their resonant frequency in the high end... And, they do tend to naturally emphasize the high end.
really ?
Post: # 15425Unread post opcode66
Sun Jun 19, 2011 10:32 pm
1K is the resonant frequency of the SX74. With the SAL rack's RIAA pre-emphasis that starts at 1K and goes up as the freqeuncy increases. Yes, really. The highs get excited by this system. A number of older mono cutterheads had a resonant frequency that was higher than 1K. Read your AES anthology.
leo gonzalez
Post: # 15432Unread post leo gonzalez
Mon Jun 20, 2011 2:18 pm
opcode66 wrote:1K is the resonant frequency of the SX74. With the SAL rack's RIAA pre-emphasis that starts at 1K and goes up as the freqeuncy increases. Yes, really. The highs get excited by this system. A number of older mono cutterheads had a resonant frequency that was higher than 1K. Read your AES anthology.
I get excited when i read your posts, but not exactly in a positive way.
there was no reason to bring "resonant frequencies" into this topic. but of course you had to because you seem to love mixing up things all the time.
You are mixing up resonant freqs with the riaa in a very funny way which could be very misleading.
please stop posting like this.
