Presto 5C Cutter Head Information or Manual
- Stevie342000
Ah good news I emailed Alan Graves and he informs me that the cutter head I just purchased is a Presto 5C.
Any one have an specs or a manual for that one? I for one doubt there will be a manual for this one but would imagine it is very similar to a 1C.
Suspect it has an resistance/impedance of 500 ohms, no idea yet it is not in my hands so can not measure it, will feed that back when I get it.
Have email Gib at West Tech for info as well as a rough idea of cost should it need to be rewound or to have the suspension replaced.
What are the impedances I should be seeing for the various impedances known for the Presto Heads? I know it is here on the forum somewhere will go trawl.
Cheers,
Thanks for all the help so far with the Rek O Kut M5 and in general.
Steve in the UK
Cheers,
Steve in the UK
- Aussie_cutter
Re: Presto 5C Cutter Head Information or Manual
The only ones I've seen by presto are 15ohms and 500ohms.. RCA made some heads at 4 and 8ohms.. and I have run into some 15ohm presto heads rewound to 8ohms.. just check with a meter when you receive it.. most presto heads are stamped with the impedance on the back plate of the head..Stevie342000 wrote:
when you finally receive the head, please post some pics, i never seen a 5C...
- Angus McCarthy
The 5C was the default head for the K-series lathes. Mine's not stamped as being wound for any particular rating, but it seems to be 16.
http://photobucket.com/Presto_5C
Hello i just came up on a Presto 5c head and was wondering if anyone knows the dc resistance of the head. I just checked and it reads 02.0.
I did a test cut with it and the recording is really low compared to a Audax rh5 cutting head a reading around 5.0.
I am sending the audio through a Akai M6 tube amp which i belive has a output impedance of 8 ohms. i belive the output of the amp is 5 watts.
Do you think the wattage of the amp is too low for the head?
Any help will do.
Any help will do.
- Angus McCarthy
Most 5Cs would probably have been wound for 16ohms AC, to match the on-board amps in the Presto K-series. I think the RH-5s I've seen were all wound for 8ohms, so it would take twice as much juice to get the same volume out of the 5C.
yes you are correct on the Audax head. It is stamped for 8 ohms. I will try a different amp which is a QSC power amp which i believe has a 4-8-16 ohm output option.
The thing that is really interesting tho is that i put a multimeter across the 5c output and it gives a reading of 02.0. i dont think thats close to 16 ohms?
i will try some test and post the results.
Well i did a test on the 5c head connected to a QSC power amp and I got a pretty good recording. Not as loud as the Audax RH5 head but it was louder which is a good sign.
I guess the reason why it was lower was because of the wattage of the Akai amp which output wattage is 5 watts.
The only bad thing now is that i guess i sent to much of a signal into the Presto head and saw some smoke come out!
Hopefully i didn't kill the head.
Does anyone know how i could test to see if the coil is still good?
Jccc wrote:Does anyone know how i could test to see if the coil is still good?
Ohm meter and visual inspection.. from my experience, it's really hard to blow out the coils on a presto head.. you have to really want to do it...
- Angus McCarthy
Really? I fried my 5C a week after getting it rewound by Gib. One moment of sibilance and POPsizzle...
Angus McCarthy wrote:Really? I fried my 5C a week after getting it rewound by Gib. One moment of sibilance and POPsizzle...
i wouldn't let gib touch anything of mine, he totally destroyed an RCA head I gave him a while back....
i think what e means is he had gib rewind the coild and file down the metal link making it sensative.. giving it a hi fi def groove.. The only reason i had him rewind one head and he reduce the 500 ohm coil in mine as well.. well he reduced the head, for what ever reason. to work with any 8 ohm stereo.. turning up 35 winds of coil will only go 5 db.. i foud this out the hard way as well. i wanted to cut loud. but its not about loud. with magnetic its about vibration and the movement of the coil generating sound. i wanted it woud for 6 db. so mine only lasted a month before i burned mine out.. jus 4 weeks.. mine is doa,, i hit my magnet with a steel hammer not a brass one.. this was a big mistake on my part,, ive asked a lot on here and no one could seem to help so i just might use a speaker instead,,
