motorino
Schematics for a M/S cod/dec console
Post: # 8626Unread post motorino
Fri Apr 23, 2010 6:44 am
Hi trolls!
I missing schematics for made a console, any help?
motorino
Post: # 9165Unread post motorino
Fri Jun 04, 2010 4:30 pm
Some block diagram on how to encode and decode the balanced signals and the point where you can insert?
Any help? :roll:
motorino
Post: # 9167Unread post motorino
Fri Jun 04, 2010 5:32 pm
I understand that l and r must be add on one side and on the other side rest L and r, and process with comp etc but I do not know is back to turn this into stereo
Any help please?
Post: # 9168Unread post markrob
Fri Jun 04, 2010 7:16 pm
If I understand corerectly, you want to know how to encode, process and decode MS.
To encode:
Mid = L+R (This is just the mono sum)
Side = L-R (The out of phase information)
You can process either signal as desired.
To reform the stereo:
L = Processed Mid + Processed Side (L+R) + (L-R) = 2L
R = Processed Mid - Processed Side (L+R) - (L-R) = 2R
Hope this helps.
motorino
Post: # 9170Unread post motorino
Sat Jun 05, 2010 4:13 am
Many thanks Mark! Now i understand :wink:
Nickou
Post: # 9182Unread post Nickou
Sun Jun 06, 2010 6:09 am
http://www.megaupload.com/?d=DTZ06NFW
this is a link to dowload the schematics of the sp72
look at the EE66 card , you have a example of a mid/ side encoder decoder with a high pass filter in the side before the recoding in L/R
or this page
http://www.proaudiodesignforum.com/forum/php/viewtopic.php?f=7&t=262&sid=601688d2aa24a7f23c6777e7e9288377
I built it and it works
Yann
motorino
Post: # 9186Unread post motorino
Sun Jun 06, 2010 2:45 pm
Ouh Yeah!! http://www.ka-electronics.com/KAelectronics/MS_Matrix/MS_Matrix.htm
Muchas gracias por la ayuda Yann!
Nickou
Post: # 9204Unread post Nickou
Mon Jun 07, 2010 7:49 am
the same thing , but passive , done with transformers
Nickou
Post: # 9214Unread post Nickou
Mon Jun 07, 2010 3:56 pm
another schema which can inspire you ... I don t have the copyright but ...Image
motorino
Post: # 9219Unread post motorino
Tue Jun 08, 2010 9:28 am
Yeah!
The transformers inspired me a lot too!
Many many thanks!
Y una cosa más, por mi parte puedes estar tranquilo en el tema de los derechos de autor jajaj :wink:
