Virtalahde
Various Scully/Westrex/Capps stuff
Post: # 25025Unread post Virtalahde
Sat Apr 27, 2013 1:52 pm
I have a ton of papers and drawing that came along with my Scully. It's quite a bit of an effort to scan all of it, so let's try it the other way around:
Is there anything in particular you're missing?
Steve E.
Site Admin
Re: Various Scully/Westrex/Capps stuff
Post: # 25039Unread post Steve E.
Sun Apr 28, 2013 8:34 pm
Anything on the qualities of pre-1948, "standard groove" styli from Capps? really, any Capps styli info might be interesting!!!
Serif
Post: # 25041Unread post Serif
Sun Apr 28, 2013 9:34 pm
Cappscoop! Styli in the shape of a cat's claw.
- Serif
Virtalahde
Post: # 25049Unread post Virtalahde
Mon Apr 29, 2013 1:44 am
I think I only have the pitch computer related stuff, but I'll have a look, there's a file full of brochures, too. I think I'll also list here what I have. One thing I've already been requested is the Scully pitch/depth system, and they're coming up.
Virtalahde
Post: # 25088Unread post Virtalahde
Tue Apr 30, 2013 11:46 am
Here's some of the stuff I have:
-Capps Vari-Pitch, full installation guide + schematics
-Scully type 261-C variable feed unit schematic
-Scully variable depth unit (transistorized) schematic, dated 11/3/60
-Scully carriage junction box schematic
-Scully push-button panel schematic, S/N sub. 560
-Scully sequence panel with banding unit schematic
-Scully relay box wiring for single phase motors
-Scully relay control panel schematic, dated 7/9/59
-Scully aluminium base wiring
-Westrex 3DII + 1700A schematics (the later model)
-Schematics + documentation for the op-amp based Westrex constant velocity EQ's
-Some documentation for setting up the 3DII recorder, seems pretty rare
And the real treat is this: Full file of Scully recording machine. Including:
-Electrical circuit details (schematics and detailed description of the action taken by each function)
-Black & white photos of the Scully lathe with number indexing
The latter is referenced to a complete set-up guide with topics:
SCULLY DISC RECORDING MACHINE
INSTALLATION AND ADJUSTMENTS
1. Machine set-up
2. Ending line adjustment
3. Lead-in line adjustment
4. Cutter drop and tape start adjustments
5. Operation of machine
6. Belt adjustments
7. Intermediate yoke thrust adjustment
8. Turntable shaft bearing adjustments
9. Feed screw thrust adjustment
10. Feed nut adjustment
11. Variable feed idler pressure
12. 8 and 32 pitch solenoid adjustment
13. Cutter saddle adjustments
14. Vacuum turntable
15. Speed changes
16. Feed ranges
17. Lubrication
Is there any interest for the whole manual? Seems like it covers everything to me.
EDIT: I now realize this topic really should be in the circuits/schematics/manuals subforum. I'll post my scans there.
Post: # 25098Unread post opcode66
Tue Apr 30, 2013 3:54 pm
I'm interested in:
skyonion
Post: # 25193Unread post skyonion
Mon May 06, 2013 6:28 pm
Hi Jaakko,
I'm could use:
Eventually I'm going to try and get my variable feed unit running and I don't have much documentation on it. The schematic would be very helpful.
Virtalahde
Post: # 25196Unread post Virtalahde
Tue May 07, 2013 3:46 am
I'm on it. I'll need to figure out how to scan it all, but trust me, I'll get there.
The schematics are pretty big sheets of paper.. I'll try to take a photo.
Post: # 25215Unread post opcode66
Tue May 07, 2013 3:10 pm
To do this correctly you need to scan it in pieces and use something like photoshop to put the pieces together into one file. If you take a picture you'll have to back out far enough to get it all in frame. But, that will make it impossible to read fine details on the schamtic like the values of the components.
Virtalahde
Post: # 25219Unread post Virtalahde
Tue May 07, 2013 3:26 pm
Could be. The large schematics are folded into A4 size, so scanning them should be easier when they're already divided in scannable chunks.
W.B.
Post: # 25234Unread post W.B.
Tue May 07, 2013 8:44 pm
I happen to be interested in the photos and:
Appears from the S/N you must have a Model 601. I always dug the lead-in and -out grooves emanating therefrom (the "8 and 32 pitch" which was a bit less on the former and a bit more on the latter).
Virtalahde
Post: # 25240Unread post Virtalahde
Wed May 08, 2013 1:57 am
Yes, it's a vary lathe model. My S/N is #644. The body of the machine says "501" in some parts (like the assembly holding the flywheel the turntable belts hook up to), but I assume this is because the molds have this same label.
My Scully is undergoing a strip-down. It was already partially torn down - first had a Capps computer installed, then gutted and the weirdest system ever was installed. A Linux computer hooked up to a motor controller. Now I'll be hooking up a new Pitch13 box from Flo.
W.B.
Post: # 25244Unread post W.B.
Wed May 08, 2013 5:42 am
Virtalahde wrote:Yes, it's a vary lathe model. My S/N is #644. The body of the machine says "501" in some parts (like the assembly holding the flywheel the turntable belts hook up to), but I assume this is because the molds have this same label.
The molds would indeed have dated to when the company was making the older Model 501's (with gearbox instead of pitch knob). The 601 which 'skyonion' has in his studio likewise has parts with 'Scully 501' molds.
Virtalahde
Post: # 25245Unread post Virtalahde
Wed May 08, 2013 6:08 am
Here's a shot I took today:
I'm trying to get it to the state that I can do "cold" test cuts with no audio by the end of this summer. Meaning TT, vacuum, heating and all that is working. The goal is to have it up and running by the summer of 2014.
Post: # 25260Unread post tragwag
Wed May 08, 2013 4:51 pm
beautiful machine!
best of luck getting it running, it seems like you have the right idea and a lot of the technical info.
bancho
Post: # 25285Unread post bancho
Thu May 09, 2013 5:43 pm
Looks great! :)
are you going to hook c37 with scully? (please do so :) )
chris king
Post: # 25965Unread post chris king
Thu Jun 13, 2013 6:46 am
Any info on Turntable shaft bearing adjustments
would be great ,pics very welcome of bearing set up
ejemmons
Post: # 26891Unread post ejemmons
Tue Aug 27, 2013 8:20 pm
I am quite interested in the skinny for the Scully 261-C Variable Pitch unit, if anyone has this it would be much appreciated. If not, stay tuned for I will draw it out myself and share it...
RA-1574E amps.
chris king
Post: # 27046Unread post chris king
Wed Sep 11, 2013 1:28 pm
CAN I HAVE ANYTHING ON THE CAPPS VARI GROOVE SYSTEM
Maistrow
Post: # 27049Unread post Maistrow
Wed Sep 11, 2013 6:56 pm
I would like something on the Capps Vari groove system also.
Thank you.
