Both side print and recordable Picturediscs
yano
Post: # 62427Unread post yano
Fri Feb 24, 2023 4:26 am
I am looking for this material: 12' Both side print and recordable Picturediscs
1 record set : 2 12' self-adhesive transparent blanks + 2 self-adhesive photopaper A3+.
if anyone has one for sale or can buy one, please send me a private message....
we agree on a price :)
boryo
Re: Both side print and recordable Picturediscs
Post: # 62447Unread post boryo
Sun Feb 26, 2023 3:35 pm
I saw your other thread and as far as I understand I think you can go with MyShank. I'm also not Souri registered so I buy from MyShank 1mm transparent blanks to make picture disks. Blank 1 -> adhesive sheet -> sticky photo paper so it sticks to the bottom of disk 1. You do the same for blank 2. The key thing here is you need something to press the picture to the disk so you don't have big bubbles. At the end you stick both blanks together since the bottom side (the photo paper) is sticky and you are ready to record.
Finewool
Post: # 62450Unread post Finewool
Sun Feb 26, 2023 6:42 pm
it’s pretty much impossible to do that without using the traditional way of of making picture disc’s (clear record, very thin pice of paper, thin sheet of vinyl)
short run and one-off cutter
lathe cut camp alumni
https://www.razzyrecords.com/
