Replacement Rubber for Neumann Lathes
gold
Post: # 60421Unread post gold
Thu Mar 10, 2022 5:48 pm
I can now fabricate and offer replacement rubber for Lyrec turntable motors as well as drive box to lead screw coupling. I’m offering the Lyrec motor mount spacers in neoprene which is close to the original material. I’m also offering them in Sorbothane. The sorbothane works better than the neoprene in damping vibration. I calculated the load on the spacers and got the correct durometer. Sorbothane is expensive and harder to work with.
I have Sorbothane discs that can be put under the feet of the Lyrec to damp more vibration. I have the pieces that fit in the Lyrec frame holes that the screws go through. Only neoprene.
Lyrec neoprene spacers $75
Lyrec sorbothane spacers $200
Lyrec frame neoprene washers $40
Lyrec sorbothane foot pads. $40
Neumann VA to leadscrew washer $25
