Atom A-101/ Vanrock E-101 For Sale
digitalkulcha
Post: # 59631Unread post digitalkulcha
Sun Oct 17, 2021 4:53 pm
Up for sale is my Atom A-101
This machine is tested, and is fully working.
This lathe cuts 7" inch blanks on 33 or 45 RPM. You can control input levels of line or mic (mono), there is an auto-level option with a compressor controlling the input level (Great for protecting your stylus). You can fine-tune the platter speed of both 33 and 45. This unit can cut PVC, polycarbonate and lacquer blanks with the correct stylus.
Comes in a beautiful suitcase, original record clamp with allen key to secure the clamp (was modified), myshank diamond stylus 462 synthetic with heating wire with stylus heat tool from Yamadan Disc Recordings and the original power cable. Runs on 100W which is the Japanese power rating, the stepdown transformer is included.
It's very compact and you can carry it with you anywhere and even start a mobile cutting booth.
Power turns on, platter turns, lathe moves forward, input + VU meter works, cutter head receiving signal, cutting head is cutting well.
Cutter will be properly wrapped and protected for secure shipping via DHL Express. Weighs 13 KG.
25x 7" 1mm from Blanq.com included.
Similar to Presto, Vinylium, Grampian, Vinylrecorder, Fairchild, Vestax VRX 2000, A-101, E-101, E101
Ebay Listing:
https://www.ebay.com/itm/224651256798
digitalkulcha
Re: Atom A-101/ Vanrock E-101 For Sale
Post: # 59647Unread post digitalkulcha
Tue Oct 19, 2021 10:50 pm
Sold!
