Anyone making Souri Vinyl Recorder Style Torque Tubes?
leemichael
Post: # 58570Unread post leemichael
Tue May 11, 2021 1:17 pm
Building a temporary stereo head for testing purposes and need some tubes.
I have everything else to build a head ready to go.
Anyone made or able to make?
Thanks
andybee
Re: Anyone making Souri Vinyl Recorder Style Torque Tubes?
Post: # 58575Unread post andybee
Wed May 12, 2021 5:11 am
are these holes conical? on neumann SX68/74 heads, this hole is conical, so the stylus just sits in there,
with a little pressure. the cone is 1:20, the spec sheet is still online:
https://www.apollomasters.com/adamanttechspec.html
leemichael
Post: # 58576Unread post leemichael
Wed May 12, 2021 5:34 am
Thanks Andy, yes they are.
Thanks for the info. Might see if I can get some machined.
Naboo
Post: # 58583Unread post Naboo
Thu May 13, 2021 4:50 am
Hi :)
I make cutting heads similar to T560.. Here's the part I make...
They have a straight tube, then I use a tiny round file to slightly taper the edge of the opening and get it to exact size,
If this would suit yours ? (the ones I make now are chunkier where the shank mounts)
I'm in New Zealand though so would take time to make and send... when I get some spare time
Dogtemple
Post: # 58584Unread post Dogtemple
Thu May 13, 2021 5:18 am
are you soldering to steel there? what are the materials?
Naboo
Post: # 58585Unread post Naboo
Thu May 13, 2021 5:23 am
Brass and silver
leemichael
Post: # 58586Unread post leemichael
Thu May 13, 2021 5:49 am
Hi Naboo
That looks perfect, will pm you now.
