Looking for Gossen 0-100mA depth current meter for Neumann lathe
Hi all, I'm looking for a Gossen meter for a Neumann lathe restoration. See attached pic. The original meter has a burned coil and broken bearings. Outer housing is 51.7mm by 54.5mm approximately. See pic. Thanks!
Re: Looking for Gossen 0-100mA depth current meter for Neumann lathe
hi tubefan
I used to use these companies for analogue panel meter repairs :-
http://www.pennineinstruments.co.uk/our-services/instrument-services
Might be worth giving them a shout???
Also :- http://www.gnw.co.uk/repair.html
Regards Soulbear
Regards Soulbear
