Gotham Amp PFB150WA with Grampian Feedback Head - Cutting System
This came off a Neumann Am31a Lathe.
All tubes are here but the system will need to be checked over.
The power cable from the amp to the power supply is not included in this auction.
There is no front cover for the amp or power supply and no cutting stylus for the cutterhead
Lathe Not Included
Details can be found here:
http://www.technicalaudio.com/pdf/Gordon_Clark_folder/Grampian-Gotham_Audio_Developments_feedback_cutter_system.pdf
Make an Offer ... is on ebay but will look after fellow Trolls
- pandapolar
