SOLD : Grampian D 8ohm
dietrich10
Post: # 31322Unread post dietrich10
Tue Sep 09, 2014 7:49 pm
Cleaning out the shelves...
Offering this here before the Bay.
$1100+ship for trolls.
Could trade for synth gear+cash etc.
Just had it magnetized and gone over before offering it out to the world.
cutting lacquers-vms70 system
Gerasim
Re: FS Grampian D 8ohm
Post: # 31351Unread post Gerasim
Wed Sep 10, 2014 5:56 pm
Hello. Why 8 ohms? The manual says 3.7 ohms.
ejemmons
Post: # 31352Unread post ejemmons
Wed Sep 10, 2014 6:04 pm
DC resistance vs AC nominal impedance...
RA-1574E amps.
Post: # 31354Unread post opcode66
Wed Sep 10, 2014 6:34 pm
When Dietrich says wound to 8 Ohms he means Impedance I believe. That way, you could use the head with any standard home stereo amplifier. When winding to 8 Ohm Impedance, you coil should read between 5.6 and 6.4 ohm DC resistance. Rule of thumb is DC Resistance is 70% - 80% of AC Impedance.
If you want to use a head like this with any old amplifier then you would want to up the resistance from the original spec. Most stereo amplifiers are made to work with 8 Ohm Impedance speakers.
If you tried to use the head wound to original specs on a standard amplifier made to work with 8 Ohm Impedance speakers, the amp would overheat. If there is no protection circuit, it might damage itself. Also, you would likely fry the coil in the cutterhead more easily this way as well.
dietrich10
Post: # 31356Unread post dietrich10
Wed Sep 10, 2014 7:53 pm
Most Grampian's impedance was 8ohm from the half a dozen that have come my way-and yes winding them for 8ohm makes the ability to use a nice clean off the shelf solid state amp for cutting much easier to do.
I do believe the Gotham cutting amps made to go hand and hand with the Grampians can run 8 or 16.
D
dietrich10
Post: # 31374Unread post dietrich10
Thu Sep 11, 2014 3:12 pm
sold
