thorens unit on ebay
Serif
Post: # 19333Unread post Serif
Sun Apr 22, 2012 10:05 am
Looks like a <<graveur,>> but reads, <<lecteur.>> Not the Hannibal kind, either. ): hehe
Thorens pickup for rare vintage lathe.
Chouette.
- Sticki Franz
emorritt
Post: # 19336Unread post emorritt
Mon Apr 23, 2012 8:03 am
I think that's a reproducer. 'Lecteur' in French means reader...
flozki
Post: # 19338Unread post flozki
Mon Apr 23, 2012 12:11 pm
yes it is a reproducer....
not a cutterhead.
Angus McCarthy
Post: # 19403Unread post Angus McCarthy
Sat Apr 28, 2012 3:07 pm
Yes, from the description: "This head Thorens –type D200 was used for monitoring during cutting process of the record lacquer."
He's even used a Lathe Trolls thread as his reference!
https://lathetrolls.com/lathetrolls-post-7625.html
greybeard
Post: # 19407Unread post greybeard
Sat Apr 28, 2012 7:18 pm
I am sort of curious: who monitors the cut with a pickup while cutting?? I don't think the combination of poor knowledge and high price expectations is particularly pleasant. eBay is for the lay people. I wonder who gets laid.
Serif
Post: # 19409Unread post Serif
Sat Apr 28, 2012 10:31 pm
As far as pickup during cut, yes, for stylus heat adjustment. Minimum hiss, but no more heat than just that, as it may tend to increase over the cut and delivers no added benefit while risking horning.
Also, I have found that test cutting with pickup within the effective radius of the target standard, while destroying its suitability as a master, demonstrates the ability for a cartridge of known type to trace and not lift out. The Feedback signal can be monitored during mastering, per se, but this is not the whole story of the results of those deflections to make a followable path for practical pickup. As you know, for mastering, only visual inspection can be used except for real-time monitor "a la lecture électrique" outside of the zone, like around Pluto and stuff. (..that is, if I may compare the discus to the planetary orbits around ol Sol. That Science show said after going red giant and swallowing up the closest three planets, it will turn, ultimately, into a diamond. Anyway, if true, we are all turning into a conical stylus in Outer Space) My mentor indicated that it was too bad the test cut area is at a radius outside of the target dimensions, since the worst effects are closer to the spindle, where time is the same, but space is traveling more slowly. fp
Still dragging a Stanton 81S. Not too good, but it sounds great. ):
- M'aud Dub
greybeard
Post: # 19412Unread post greybeard
Sun Apr 29, 2012 3:37 am
I have used the cutterhead itself as a pickup for checking on the cutting noise while cutting. In a professional setup this would make the routing of the signals more complex. In my case it has been when trying out different mastering materials, and I had the time available.
I like the constant-time--space-travelling-slower analogy, and I suspect that there is a deep truth hidden there. Come to my Higgs bosom.
