Ortofon DS522 Styli Wanted
Nigie
Post: # 2164Unread post Nigie
Sat Dec 29, 2007 12:59 pm
Does anyone know who sells the styli for Ortofon DS522 cutter heads ?
Dimensions are 4mm length and .73-.75 mm diameter.
Is there a stylus from another head manufacturer that will fit those dimensions ?
Thanks
Nige, UK
Cutterwoller
Post: # 2204Unread post Cutterwoller
Sun Jan 20, 2008 12:57 pm
Nigie
Post: # 2283Unread post Nigie
Sun Feb 10, 2008 3:49 pm
Thanks, but I don't think they are listed.
The only 2 there are Ortofons with an alloy shank. Mine do not have a shank as such - it is all part of the stylus,
Thanks
Nigel
jtransition
Post: # 2646Unread post jtransition
Thu Apr 24, 2008 2:30 pm
Have you got the collet and correct tools?
I may have a few left i will have a look.
Regards
Jason
Aussie_cutter
Re: Ortofon DS522 Styli Wanted
Post: # 22606Unread post Aussie_cutter
Fri Jan 18, 2013 4:19 am
I'm also looking for Ortofon DS522 Styli. Please PM me if you can recommend a source.
Thanks
Henry
Wanted: Stylus or Manual for Ortofon DS522.
Also interested in any record cutting or pressing items for sale in Australia.
studiorp
Post: # 22608Unread post studiorp
Fri Jan 18, 2013 5:09 am
Hey Nigie, have you the dimensions of stylus holder hole ?
dubcutter89
Post: # 22673Unread post dubcutter89
Sun Jan 20, 2013 1:33 pm
the stylus for the mono ortofons is 0.75mm diameter straight solid ruby (saphire...), so the hole in the armature is just a little bigger.
also needed is the so called collet ring, which goes around the armature (conical) reducing its inner diameter so that the stylus is held in its place.
original stylus # is 329 (without SH which stands for aluminium SHank..)
if anyone knows a source, old stock, new manufacturer or has some lie around please let know..
or might be possible to ask apollo if they do a batch of 329 without shank...
lukas
Aussie_cutter
Post: # 22740Unread post Aussie_cutter
Wed Jan 23, 2013 7:09 am
Hi
I understand that the sapphire stylus for the DS522 has a length of 4 mm, cylindrical shaft. The diameter of the shaft is specified to be between 0.75 mm and 0.73 mm.
Does anyone have a photo/drawing of the collet used to hold the sapphire? I think mine is missing.
H
dubcutter89
Post: # 22741Unread post dubcutter89
Wed Jan 23, 2013 8:11 am
I will take some pistures of the head, connector and stylus mounting next time I come to my cutting room (next week)
L
powerstrip
Post: # 22761Unread post powerstrip
Wed Jan 23, 2013 3:05 pm
Getting to this point is still a chore- You need to think about how to remove the 2 layers of rotating plates to gain access to the armature.
Removing the collet without tool?
Dip a toothpick penetrating oil, touch tip lightly around upper edge of collet as head sits propped in upright position,wait a couple minutes, lightly pull away collet with gentle rotation.
Now you must mount stylus and be sure azimuth is correct, which I am unsure of how to precisely set/adjust.
Here is a pristine stylus for the ortofon dss d22
Dont get exited yet but i think someone is about to cut some for us...stay tuned
NOW, Does anyone have a picture of this freakin' impossible to find TOOL??? ;)
powerstrip
Post: # 22790Unread post powerstrip
Thu Jan 24, 2013 3:22 pm
Attention:
Look no further for ortofon DSS 522 Styli!
I convinced the people at apollo masters to cut more.
Contact Sam at apollo/transco and tell her you want a stylus for dss522, reference ortofon styli number 329 (WITHOUT SHANK)
She will ive back an estimate, and is saying they are basically ready to cut as soon as she gets some calls about it.
www.apollomasters.com
USA : 951-849-8831
