Groove cutting into blank PVC slice?
TL7
Post: # 48666Unread post TL7
Thu Dec 07, 2017 7:47 am
Hello.
I can find blank PVC/polystyrine slices online:
https://www.amazon.com/Styrofoam-Arts-Crafts-Discs-Circles/dp/B006SS2ARY
How can I easily cut grooves into them to prepare the PVC/polystyrine discs for vinyl recording?.
I could select density and depth.
Less depth allows for more re-recording cycles, but with higher danger of the needle sliding off.
More density allows for more recording length on same space, however a narrow width of the spiral track can also cause sliding off and sacrificing audio quality as much as recorder incompatibility. I will find a balanced density manually.
Re: Groove cutting into blank PVC slice?
Post: # 48667Unread post markrob
Thu Dec 07, 2017 10:06 am
You don't pre-cut any grooves. The groove is made during the cutting process. You will need to design a lathe and cutter head to accomplish this. Do some searching here and you will see quite a few examples of DIY lathes and heads.
