It's hard to know whether you will keep working on this or not, but for now I think you deserve to hear: You've done it!
Thanks Mark. Those mechanical changes sure made a difference to the channel separation!markrob wrote:Great work! I think you nailed it!
Well, I have a few more things to try related to FB and the EQ within the FB loop but the head with these drivers is locked down and done! Just too big and clunky. Something based on what was learned is possible...Bahndahn wrote:It's hard to know whether you will keep working on this or not...
I've done something for sure, and I like it! Not sure if I've done all that I can do but I thank you for the kind words. I'm very happy to hear the mechanics are working correctly now. I'm not going to do too much more on this one, but we all learned several lessons having to do with insuring drivers can only move in and out at exactly 45 degrees in all planes. We also learned the importance of the Vertical Cutting Angle as it relates to channel separation. All these lessons can be applied to other drivers and other head designs.Bahndahn wrote:...but for now I think you deserve to hear: You've done it!
Thanks Patrick. I'm getting ready for the final testing... Had to make a few new mounting adapters to make it easier to mount and dismount the head, and also the brackets for my counter balance setup on the lathe. Since the head is so heavy, the counter balance is needed. It had to be reworked a bit since I made that for the plastic version.socialroots wrote:...just wanna thank you for being so dedicated to the groovescribe project, and mostly for being so kind as to share openly all your triumphs and failures ...
