Who can help me with my VR T560 cutterhead?
marct
Re: Who can help me with my VR T560 cutterhead?
Post: # 39394Unread post marct
Sat Jan 02, 2016 10:41 am
Snug Music wrote:Hey marc,..
Happy hew year 2016
The Black ring of tweeterholder us this peace a rubberring? How stifness are this peace? Rc-wheel ?
Tgx Scotty 8)
Hi Scotty, which black ring do you mean because you only have to fill the tweeter with liquid rubber....
Or do you mean something else?
Greeting,
Marc
Snug Music
Post: # 39395Unread post Snug Music
Sat Jan 02, 2016 10:58 am
Happy hew year 2016
Tgx Scotty 8)
Greeting,
Marc
This Peace!! Rubber or PVC ?? >>
marct
Post: # 39396Unread post marct
Sat Jan 02, 2016 11:02 am
Snug Music wrote:
Happy hew year 2016
Tgx Scotty 8)
Greeting,
Marc
No, the outside of the tweeter is normal plastic and there's no rubber ring.
Snug Music
Post: # 39397Unread post Snug Music
Sat Jan 02, 2016 11:04 am
Snug Music
Post: # 39398Unread post Snug Music
Sat Jan 02, 2016 11:07 am
Ahaa,...OK,..
i see this RC Peaces and think ..thats it! :mrgreen:
Ok,..u say thats Plastik... :shock: OK,..Thanks :lol: 8) :wink: :wink:
EpicenterBryan
Post: # 39401Unread post EpicenterBryan
Sat Jan 02, 2016 1:18 pm
Hey,
you could put some hub caps on there for a custom look ;)
Snug Music
Post: # 39402Unread post Snug Music
Sat Jan 02, 2016 1:43 pm
EpicenterBryan wrote:Hey,
Heheee...Yeah
Pimp up my Cutterhead!!! :mrgreen: :mrgreen: :mrgreen:
marcy108
Post: # 39448Unread post marcy108
Tue Jan 05, 2016 5:54 am
this thread is very interesting.thank you all.
i made cutterhead structure image.
follow is my question.
1.what material is CONE?
can i buy or make it?
2.how to be fixed STYLUS HOLDER? by LIQUID SILICONE?
3.STYLUS HOLDER touch TWEETER SPEAKER?
Please correct my mistakes in this image if you find them.
thanks.
best regard,MARCY
Snug Music
Post: # 39450Unread post Snug Music
Tue Jan 05, 2016 7:54 am
marcy108 wrote:this thread is very interesting.thank you all.
thanks.
best regard,MARCY
hey Marcy, you may have dimensions of the head in mm? so I can create a 3D image in Vector! with all details!
The pushrod is not connected to the tweeters, only connected through the Cone !!! This is glued to the top of the cone with Loctite.
The hollow cone is filled with silicone, this is correct... 8) :wink:
greeting Scotty 8) :wink:
juba bc
Post: # 39452Unread post juba bc
Tue Jan 05, 2016 11:23 am
what is the use of silicone inside the cone ?
Snug Music
Post: # 39453Unread post Snug Music
Tue Jan 05, 2016 11:31 am
juba bc wrote:what is the use of silicone inside the cone ?
As far as I know, this removes a specific frequency range, but as far as I'm still not to say this with 100% certainty. but I have yet to measure me to be really safe :roll:
cheers...
Scotty :wink:
Fatrecco
Post: # 39454Unread post Fatrecco
Tue Jan 05, 2016 1:02 pm
I also ordered these speakers. Thank you for finding it ! I built now 4 heads out of tweeters, they costs all about 20€ to 40€ and got the issues to be a bit differently, althought they are the same type. I know the price makes a part of the soundquality , but I only see my lathe as a test-lathe. Trial and error...
It seems that Souri doesn't use the "normal" way of creating the mechanic. On the pictures I found no single torque-tube. There are two of them. They are linked to these aluminium rods. The rods got to be elastic to allow the stylusholder to move in the 45/45 directions, or am I wrong ??
mfG
Fat
Snug Music
Post: # 39456Unread post Snug Music
Tue Jan 05, 2016 1:35 pm
Fatrecco wrote:I also ordered these speakers. Thank you for finding it ! I built now 4 heads out of tweeters, they costs all about 20€ to 40€ and got the issues to be a bit differently, althought they are the same type. I know the price makes a part of the soundquality , but I only see my lathe as a test-lathe. Trial and error...
mfG
Fat
the rods are arranged a little offset, thus fulfilling its role as (Torque) I'll call it signal crossroads! :mrgreen: :mrgreen:
dimi751
Post: # 39457Unread post dimi751
Tue Jan 05, 2016 4:09 pm
I've already build my diy cutter head with very good result this is what I done
1. Bye car tweeters make sure there are at least 100w
2. You can use standard aluminium angle I 3D printed
My cutter head design
3. Make some small paper cones and make sure they
Fit on the speaker cone then I dipped the cone in lacer
Let it dry for one day
4. Then I super glue or you can use any glue to glue the cone on the speaker cone it's also very important
Not to put too much glue on the cone this will affect
The sound spread the glue thin on the cone then put the dipped cone on the new tweeter cone. Let this dry properly
5. I used size 10 sewing needle and and glued a small brass bead which fitted the vinyl recorder type diamond I got from Steve from my shank perfectly again make sure you let this dry property.
6. Then poke some holes into the cone and glue the sewing needle into the cone make sure it looking lined up.
7. Then you need to glue some more needle on the side to support the structure.let everything dry.
8. Then I painted over the glue with silver paint to hide the glue marks, it now looks like it was welded.
9. Fit you diamond now you can cut.
I'll email some sounds from cutting soon sorry for the writing I know pictures are better but I do t have much time To take pictures and post.
A lot of my research came from this site everything you need to make a day head is here you just need to search for it.
And let's not forget the Heros that made this possible for me to even think to attempt this crazy thing
Thanks to
Mark rob
Please visit marks Comcast site really interested reading and this is where I got the idea from dipping the cones in lacer. Sorry forgot the link to the site.
Dimi
aaron
Post: # 39458Unread post aaron
Tue Jan 05, 2016 4:55 pm
Where did you get the bead from to fit the diamond into? I thought you needed a tapered hole
dimi751
Post: # 39460Unread post dimi751
Tue Jan 05, 2016 5:25 pm
Hi
I used brass Beads from the art supplies store
When I fit the Diamond it was a little loose so I got
Some small long nose pliers and squeezed the bead
Until the diamond shank fitted into the bead snugly.
I did not drill any tapered holes.
marcy108
Post: # 39467Unread post marcy108
Wed Jan 06, 2016 12:55 am
hi Scotty,thank you for your reply.
i don't have any dimensions.this is just rough image.
thank you for letting me know it.
i guess hollow cone is filled with silicone,but silicon doesn'tt touch tweeter.is this right?
hi DEMI,thank you for sharing your knowledge.
what king of paper did you use for cone?
and what is "lacer"?
please check attached image.
top of this needle have hole.
did you use like this sewing needle?
i updated my image.
please correct my mistake in this image if you find them.
thanks.
best regard,MARCY
The Shank
Post: # 39474Unread post The Shank
Wed Jan 06, 2016 11:27 am
The fearing topic for Souri... Here we are.
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Cutterheads - HeLiX23
juba bc
Post: # 39482Unread post juba bc
Wed Jan 06, 2016 4:09 pm
lack only now unraveling the Souri feedback system :mrgreen:
