Half scale VMS 70
evildrome
Re: Half scale VMS 70
Post: # 57547Unread post evildrome
Sun Jan 17, 2021 6:24 pm
Was in the shop today.
Made the 2 screws to hold the scale to the side of the way body.
I have some black plastic backed aluminium that'll do for the scale.
Not sure how to apply the lettering to it...
Still need to drill holes in it.
I don't have a shear so I needed to cut the thin aluminium by hand. I scored it with a knife and held it between two parallels to wiggle it till it cracked along the score line.
evildrome
Post: # 57656Unread post evildrome
Thu Jan 28, 2021 12:37 pm
I made the pointer that hangs on the swan neck.
I still need to make a shaft to mount it properly.
evildrome
Post: # 57704Unread post evildrome
Tue Feb 02, 2021 12:29 pm
Its coming together...
evildrome
Post: # 57707Unread post evildrome
Wed Feb 03, 2021 3:33 pm
Incremental progress...
evildrome
Post: # 57715Unread post evildrome
Thu Feb 04, 2021 3:39 pm
more incremental progress...
evildrome
Post: # 57716Unread post evildrome
Thu Feb 04, 2021 3:42 pm
And.... After 2 years, I have completed the major mechanical components.
Still need to make a suspension box, cutting head & decide where to mount the leadscrew drive motor...
basplin
Post: # 57720Unread post basplin
Thu Feb 04, 2021 8:16 pm
Omg. This is amazing!!!
juba bc
Post: # 57721Unread post juba bc
Thu Feb 04, 2021 8:34 pm
very good job !
dmills
Post: # 57727Unread post dmills
Fri Feb 05, 2021 11:29 am
Next up, a half scale SAL74B?
Actually with modern parts that should be entirely doable...
The half scale Studer Preview deck might be a bit of a pain however, while cassette tape is 1/8th of an inch, so the media is available, there may be quality issues.
Wish mine was going as well, just had a pile of laser cut steel turn up with the both the base plates being wrong in one way or another, a kinematic constraint problem on one and a simple case of measurement screwup in the other.
Still, laser cut steel is basically cheap, so it is mostly the waiting that is annoying.
record cutter 76
Post: # 58075Unread post record cutter 76
Sun Mar 21, 2021 4:20 am
So cool congratulate you on youre nice jobb impressed by youre wourk best regards from sweden
evildrome
Post: # 63481Unread post evildrome
Wed Oct 04, 2023 11:23 am
Hi All,
As with all things, it takes longer than you think it will.
If I had some money I could speed up the next part of the project (mostly electrical / electronic parts).
Would anyone be interested in making their own half scale VMS or making it from parts?
I'm considering selling new parts based on my work so far.
Basically you can buy the bits you don't feel comfortable making and make the ones you do feel comfortable making.
farmersplow
Post: # 63485Unread post farmersplow
Wed Oct 04, 2023 4:05 pm
Hi All,
I understand well what you mean!
The project turned out great! I hope you can find the necessary money to complete the artwork. I would love to see it finished! (But as we know: as with all things, it takes longer than you think).
Congratulations
Thomas
evildrome
Post: # 63489Unread post evildrome
Thu Oct 05, 2023 7:30 am
Hi Thomas,
I was looking at your cutter head. Its very professionally done but I wonder if you shouldn't just bite the bullet and go 100% home made by winding your own coils.
While tweeters may be convenient I can't help but think they are not ideal and given the splendid effort you have already made I can't think that winding coils would be much of a task for you.
Also, and for me this is the most important advantage, it gives you complete freedom over the design and fit of the connection from the coil to the bridge which seems to be a problematic area.
Because I have wound coils, I suspect I am biased about the effort required but for someone with your skill and attention to detail, I cannot think it will be much of a challenge for you and may end up saving you effort further down the line.
Whatever you decide , your work is an inspiration to us all.
farmersplow
Post: # 63490Unread post farmersplow
Thu Oct 05, 2023 8:18 am
Thanks for the motivating words! And I would also like to thank you for the constructive criticism and the suggestion to wind the coils myself. In the meantime I have reworked the cutter head (CH-9 I will post soon) and wound the coils myself. Only the housing with magnets from the resonance speaker I have taken over - here the effort of self-manufacture is not worth it.
Thanks and good luck with your project
Thomas
evildrome
Post: # 63496Unread post evildrome
Fri Oct 06, 2023 4:19 am
Yes, retaining the housing and magnet is a sound idea.
I look forward to seeing more of your posts on this project.
