Who can help me with my VR T560 cutterhead?
fredbissnette
Re: Who can help me with my VR T560 cutterhead?
Post: # 52707Unread post fredbissnette
Tue Mar 26, 2019 1:18 pm
have you thought about using exciters? i got some from parts express and made a head and got decent results form embossing im not sure how they would fair for cutting.
Teddy
Post: # 57100Unread post Teddy
Sat Oct 31, 2020 9:28 am
Hey Ruben, Super huge thanks for these posts and sharing a research you made.
We have the same problem with the cutterhead. Burned one channel and don't want to have busyness with Souri. Most asked people don't want to get involved of fixing it. So probably we will follow your way, and Im really curious how it went to you? Did aluminium helped? how about epoxy? and is the silicon ring is necessary? :)
Teddy
Post: # 57101Unread post Teddy
Sat Oct 31, 2020 9:33 am
rubenr wrote:
Sun Jan 27, 2019 5:59 am
Friday 25-01-2019 23:15 Austria:
I coneccted first de Amp 380x 380, and after the power supply, AND CLIC " POP " BOOOM, The left tweeter was broken.
OK 2 days after, whit 4 hours sleep whit my eyes reds for too much computer, i told yoou some think,
1 First use fuse 1A o Whit minus A.
2 NEVER more make on the amp first.
3 read all forum , al post, investigue all.
4 make broken the conical form from tweeter.
5 Put one meter in your hand and enjoy.
6 Buy, 2 diferents models Pro-Tech 200W 2/419 buyed, Rockville RT6 240 W buyed.160 euros in total. and stay in relax for many days. but all 25mm
7 Whit a lot nervius searching for 36 hours, no sleep, only cafe and find the "original tweeter" (NX30 - Image Dynamics 30MM)
8 Sleep, 4 hours. whit nightmares about the machine.
9 You can write your history, and put in the forum.
10 ...... Next week more steps.
Maybe helps.
https://www.templatemaker.nl/index.php?template=cone&lang=es
https://www.ebay.com/itm/123592878889 for test, i want no more things broken.
https://www.red-carparts.de/car-hifi/car-hifi-auto-lautsprecher/hochtoener/phonocar-hochtoener-tweeter-pro-tech-200w-2-419
https://www.rockvilleaudio.com/2-rt6/
https://www.woofersetc.com/p-4996-nx30-image-dynamics-30mm-silk-dome-tweeters-with-rotating-flush-mount-socket.html
I think need it. I need one feedback in my email. https://www.woofersetc.com/c-172-speakers/c-24-tweeters/p-5718-xs-28-image-dynamics-28mm-silk-dome-tweeters-pair.html
Best regards Rubén.
dubvinyls.com
Hey, big thanks for sharing this research! Im really curious how it went? did other tweeters did the job?
Teddy
Post: # 57103Unread post Teddy
Sat Oct 31, 2020 10:42 am
aaron wrote:
Tue Dec 29, 2015 2:12 pm
How thick are the wires that come out of the cones and connect to the stylus holder? Can you tell what type of material it is?
not sure about the material but these are tubes, not wire. for light weigh.
jonty2k
Post: # 57112Unread post jonty2k
Mon Nov 02, 2020 8:12 am
Hi Teddy, sent you a private message a couple of days ago.. :-)
Thelurker
Post: # 57163Unread post Thelurker
Mon Nov 09, 2020 2:10 pm
Maybe helps.
Best regards Rubén.
dubvinyls.com
Litterally none of those tweeters are suitable and are far from original. They are all SILK DOME, you require Titanium dome.
rubenr
Post: # 58129Unread post rubenr
Thu Mar 25, 2021 5:09 am
Nein! No, i repaired more than 10 cutter heads, and are Silk :)
Thelurker
Post: # 58231Unread post Thelurker
Tue Apr 06, 2021 2:22 am
No they are not silk dome! Plenty of photos on here of original tweeters to prove this plus I’ve seen them myself personally.
Maybe you’ve found silk dome that work ok but they are nothing like original.
soeffingodly
Post: # 58241Unread post soeffingodly
Wed Apr 07, 2021 11:05 am
Pretty sure the original tweeters that were used in the head are no longer in production, so who knows what drivers are being included for the new head builds. :shrugs:
Thelurker
Post: # 58245Unread post Thelurker
Thu Apr 08, 2021 2:23 am
Souri stock piled a ton of the original drivers and he still has some.
There’s no evidence of anyone ever dissecting an original Souri head with silk domes.
GEEKKCC
Post: # 60491Unread post GEEKKCC
Mon Mar 28, 2022 7:12 am
I am thinking of selling my T560, Any offers let me know.
Many thanks
blackmoondivision
Post: # 68330Unread post blackmoondivision
Fri Oct 24, 2025 12:16 pm
Hello everybody!
Is anybody here who successfully repaired the broken tweeters on T560 cutter head?
Got the issue with one channel. The multimeter reading suggests the tweeter has gone. Have to replace the tweeter and make it work.
Cut cut cut ;-)
Thelatheofus
Post: # 68344Unread post Thelatheofus
Fri Oct 31, 2025 1:22 pm
A guy named ruben rubio was posting on fb groups that he made replacement drivers for the t560 cutterhead. I have no idea if it's true or what quality to expect. He got banned from the t560 users group because he spammed them a lot. So he was kind of problematic but his advices helped me solve an issue with my machine.
I would probably change for a new cutterhead from TKV instruments or LA Mastering
leemichael
Post: # 68348Unread post leemichael
Sat Nov 01, 2025 1:44 pm
Thanks for the mention, full details on the Nebula here:
Price increases after Xmas
https://systemphonics.com/shop/cutter-heads/nebula/
rubenr
Post: # 68440Unread post rubenr
Tue Nov 25, 2025 4:27 pm
If you need help, just text me.
Greetings!
Kungfupanda
Post: # 68674Unread post Kungfupanda
Tue Jan 06, 2026 6:00 pm
hi, does anyone know the name if this part?
Kungfupanda
Post: # 68687Unread post Kungfupanda
Wed Jan 07, 2026 8:34 pm
Snug Music wrote:
Sun Feb 07, 2016 11:33 am
hey,..
here a little images ( Pic ) how to setup an Dyn. Cuttinghead with Tit.Dome Tweeter ( Red-Car-Parts )
hi, do you mind sharing the name if this part?
rubenr
Post: # 68696Unread post rubenr
Thu Jan 08, 2026 3:54 pm
14 mm alu tube...
Kungfupanda
Post: # 68698Unread post Kungfupanda
Thu Jan 08, 2026 7:27 pm
14 mm alu tube...
I can't find it online with the cone tip. I assume its has inner screw threading as well
