Vinyl Recorder - Is the Vinyl Optimiser a good enough EQ?
Hi guys Im new here.
I own the VR.
Just wondering about the Vinyl Optimizer that is with the lathe, is it a very basic eq? Would it be better to get a much better rack mounted 31 band EQ? Im told it has compression built in as well.. Or is it just a waste of money ?
I dont seem to get much control out of it thats all.
Im sure you experienced lathe trolls have the answer here.
Ive attached the pictures of the eq..
I own the VR.
Re: Vinyl Recorder - Is the Vinyl Optimiser a good enough EQ
Also, off topic, what is Souris pink "Denoiser" spray made of ? I want to get it locally.
ha ha, the denoiser spray is just an antistatic fluid, you can buy
it at maybe at your local record supplier, in germany www.protected.de
An external EQ can help, but if you don´t have a feedback head, it will be
nearly impossible, to get a flat frequency response, because of the mechanical
resonances... If I am wrong, please correct me!
Thanks mate ! Appreciate your help !
