sound quality of the pressed records
jannovotny
Post: # 53777Unread post jannovotny
Mon Jul 29, 2019 9:20 am
Hi, being a newbie in record pressing I would like to ask:
We have Pheenix Alpha presses and sound of our records is a bit upper-mids-heavy, and/or "louder", compared to testpresses made by our stampers supplier. It is nothing really bad (customer-approved :-) ), but the records just seem to be like "run-through-aditional-compression" or having less space/breath or something like this in A/B listening tests.
Do you have any hint for healing this? Or at least where to start searching/changing parameters.
Thanks
Jan
Re: sound quality of the pressed records
Post: # 53789Unread post Aussie0zborn
Tue Jul 30, 2019 12:25 pm
You're saying that pressings made by your stamper supplier sound different to the pressings you make from the same stampers - is that right?
You are comparing these two different pressings on the same turntable, right?
As you know, you can't change the tonal quality of the record, add compression or turn up the volume at the pressing stage so this sounds odd, hence seeking clarification. It sounds like you might be making a better record. :)
jannovotny
Post: # 53842Unread post jannovotny
Tue Aug 06, 2019 3:40 am
Yes, from the same stampers and compared on the same turntable.
Is there a chance to influence the sound in any way by changing the parameters of the pressing process?
Post: # 53848Unread post Aussie0zborn
Tue Aug 06, 2019 7:43 pm
That's bizarre. I hope somebody has an answer for this.
GeorgeZ
Post: # 53884Unread post GeorgeZ
Fri Aug 09, 2019 8:43 am
It is measurable and sometimes also audible that lacquer / vinyl / pvc / copper master plate / nickel mother can have a little bit different sound on the same turntable+same stylus due to elasticity or rigidity of the particular material. But there should be no audible differencies when using various vinyl formulations. Maybe the nickel mother had been wrongly dehorned (polished) when your new stamper was made...
Jiri Zita
Premastering specialist
GZ Vinyl / GZ Media Lodenice
Czech Republic
llary
Post: # 53895Unread post llary
Mon Aug 12, 2019 1:34 am
Are you maybe talking about playing the mothers?
Pressing from the same pair of stampers you could certainly get differences in surface noise and pressing artifacts, but not a difference in volume or EQ.
