How record thickness is controlled
boryo
Post: # 47153Unread post boryo
Tue Jun 20, 2017 2:38 am
Hello trolls, thank you for all the information that you are sharing here!
Learned a looooooot of stuff reading here in the forums but my curiosity is still missing something.
How the record thickness is controlled in the process of pressing? Is it there some piece of metal which keeps both matrixes separated for let's say 2mm or this is combination of amount of pressure per time?
Thanks,
Bob
Re: How record thickness is controlled
Post: # 47154Unread post Aussie0zborn
Tue Jun 20, 2017 8:05 am
The depth of the mould cavity determines the thickness of the record.
pcylfe
Post: # 47156Unread post pcylfe
Tue Jun 20, 2017 10:42 am
Aussie0zborn wrote:The depth of the mould cavity determines the thickness of the record.
Am I right in thinking that you need different moulds to produce different weights of records? (i.e one mould for a standard 130-140g record and a different one for a 180g record?)
If so that's a considerable amount of investment to buy specific moulds tp produce 180g records which won't necessarily be used 100% of the time...
Pcylfe
Insta: Jungle.incoming
Post: # 47176Unread post Aussie0zborn
Wed Jun 21, 2017 10:29 pm
Yes that is correct.
