Need Lathe Cuts in EU
Paul1979
Post: # 65986Unread post Paul1979
Thu Oct 24, 2024 2:41 am
Hello there !
I am not sure if I chose a right place to ask sch question, but I will try. In the case it is not approved, please remove or delete it.
I am looking for a small record plant in Europe (continental or UK also) to cut 50 to 80 copies of 12-inch vinyl or acetate.
I have already prepared audio ready to go.
Thank you,
Paul
Re: Looking for some small record plant to cut the vinyl/acetate
Post: # 66003Unread post piaptk
Sat Oct 26, 2024 1:49 am
Try GZ Media in Czech. Their minimum is 100, but it will be cheaper than having someone cut 80 copies in real time.
Paul1979
Post: # 67224Unread post Paul1979
Mon Apr 07, 2025 5:43 am
Still valid if someone's ready to cut small quantities and willing to help.
Continental Europe preferable.
misjah
Post: # 67246Unread post misjah
Thu Apr 10, 2025 10:49 am
Many pressing plants have minimum of 50 so should suit your needs. Probably cheaper to press than have 50 copies cut. Try Krakatoa, Madvinyl, RPM, Green Lakes etc etc.
drdub
Re: Need Lathe Cuts in EU
Post: # 67269Unread post drdub
Mon Apr 14, 2025 3:03 am
We cut these quanitites in one-off. Based in austria. But it's not cheap cause it takes a lot of time.
Check out our shortrun-bundles: https://drdub.com/en/order/vinyl-shortruns/
Production Time: Usually 2 weeks but might take longer for big orders.
*** www.drdub.com ***
