Hey Everyone,
I'm the production director here at Gold Rush Vinyl in Austin TX. We run two Viryl Warmtones and two Pheenix AD12s
I'm hoping to get your thoughts on two recurring and consistent issues we have with them.
First, the Warmtone -
We have consistent sticking issues where the pressed record won't release from the bottom stamper. The weird thing is that it's not a process thing - it seems to be static electricity that's holding the record down. When we reach in to remove the record, it comes out easily, and we can't figure why the vacuum arm can't lift it off, even though the vacuum level is correct. Has anyone ever had static issues that stopped a record from releasing in the press?
Second, the Pheenix -
We have the worst time with the bottom pin staying up after the press opens and the record is released. The pin stays up, then when the puck and labels go in for the next cycle, the bottom label snags. Thought on getting that thing to stay down. PVC too hot (material is gummy and drags on the pin) or too cold (material is seized around pin keeping it from retracting)?
Neither of these problems happen all the time, they're just our top two issues that we're having trouble ridding ourselves of.
Any thoughts are greatly appreciated! Thanks guys!
