juke box large hole lathe cuts
Post: # 58904Unread post tragwag
Fri Jul 02, 2021 8:34 am
I've been making a lot of jukebox cuts lately and wanted to see if anyone had an elegant solution for large hole blanks?
the trusty yellow plastic spider inserts have popped out and ruined the cut more than a few times.
I have a metal Presto branded 45 insert but it's too tall to be used with the clamp that holds the blank down.
any thoughts?
misjah
Re: juke box large hole lathe cuts
Post: # 58905Unread post misjah
Fri Jul 02, 2021 9:29 am
I’d have something machined. Should be pretty easy for somebody with a lathe (the metal kind) :)
David34
Post: # 58973Unread post David34
Mon Jul 19, 2021 6:04 am
A mate of mine had a 3D printer and made a "shim" for me of plastic. Works well.
Post: # 58983Unread post tragwag
Tue Jul 20, 2021 11:29 am
cool! does it sit below your standard hold down clamp?
timinbovey
Post: # 59062Unread post timinbovey
Tue Aug 03, 2021 5:00 am
Back in the 50's Webcor made 45 hole adapters made of steel. I have found these to be the most stubborn, durable, and indestructible 45 centers ever made. I have bags full of them - having bought and hoarded tens of thousands of 45's over the years, I've accumulated a lot of various centers. I do not know if they would work for your purposes, or if they could be too difficult to get in and out of anything but a plastic 45, but they're pretty flat and hell for stout. If you google "webcor 45 adapter" or webcore 45 center, etc you should be able to pop up a photo of one on google. If you want to try one PM me your address and I'll toss one in the mail. Would be interesting to see how they work!
Tim in Bovey
Post: # 59102Unread post tragwag
Mon Aug 09, 2021 2:16 pm
Tim in Bovey
oh awesome, I'll send a PM thanks Tim!
