Dashpot Oil - What Are You Using?
PMST
Post: # 56459Unread post PMST
Sat Aug 08, 2020 11:31 am
I thought it might be a helpful resource for anyone using oil based dashpots and need to find a replacement oil, or for a new DIY set up etc, just one thread with what people are using for referencing.
I cut on a VR, didn't have access to Souri's oil so I used Motul SAE 50 mono grade oil. The viscosity appears to be pretty close, I settled on 40g counter weight, then my normal 15g final weight. So far this seems to be working for me...... If people who are using something different feel like posting, then please do, resource threads can be extremely useful!
emorritt
Re: Dashpot Oil - What Are You Using?
Post: # 56465Unread post emorritt
Sun Aug 09, 2020 10:37 am
For just about any dashpot, traditionally glycerine is the fluid of choice. If you could get a silicone fluid that was of the proper viscosity that would work as well, but most silicone materials are too "thick" for dashpot use. Oil of any kind probably wouldn't be a good choice because of viscosity. Glycerine has about the perfect viscosity for use in lathe dashpots. For a VR system, I don't know what is recommended as the system might be so different than traditional lathes you might need something "thicker."
handcut
Post: # 56466Unread post handcut
Mon Aug 10, 2020 9:15 am
Prestos - vegetable glycerine. Works just fine. It's what is recommended in the manual...
Vinyl Recorder - RC shock silicone oil. RC tires on the cutterhead, so seems quite fitting! I believe it is 500cSt or around 60wt. Can't remember! I just asked for the middle of the range expecting to go higher or lower. Very close match to what was in the syringe I got from Souri. I tried all sorts when I ran out. Even 3-in-1 at a push which was ok on 7's but not good on 12's.
Happy cutting.
SueDenim
Post: # 56467Unread post SueDenim
Mon Aug 10, 2020 9:56 am
Thanks for the info. From what I know, 500cSt is around 40wt.
Phinster
Post: # 56492Unread post Phinster
Wed Aug 12, 2020 8:07 am
I use a Neumann VMS suspension box, they never specified what grade to use, but 3 in One oil works perfectly and it doesn't
weep all over the place!
jonty2k
Post: # 56496Unread post jonty2k
Wed Aug 12, 2020 11:36 am
Hi Sue, not the shock stuff.. it comes in a various viscocity's :-)
https://www.modelsport.co.uk/core-rc-silicone-shock-oil-500-cst-60ml-/rc-car-products/366812
SueDenim
Post: # 56500Unread post SueDenim
Wed Aug 12, 2020 4:07 pm
500 cSt = 40 wt
It even says so in the second image on your link's page :)
jonty2k
Post: # 56502Unread post jonty2k
Thu Aug 13, 2020 4:49 am
Oh yeah.. should have blown up the image :-)
Its not the legs that go first Sue! its the eyes :-)
Post: # 56503Unread post Aussie0zborn
Thu Aug 13, 2020 5:22 am
I use a Neumann VMS suspension box, they never specified what grade to use, but 3 in One oil works perfectly and it doesn't weep all over the place!
Can you specify the brand and type? Thanks in advance.
Soulbear
Post: # 56504Unread post Soulbear
Thu Aug 13, 2020 5:59 am
Maybe it's not a known brand in the antipodes, but I think the reference is to this Aussie :-
Soulbear :P :) :D
gold
Post: # 56524Unread post gold
Fri Aug 14, 2020 12:14 pm
The original oil specified was Telus 29. They then specified a silicone oil who’s specs I forget. Telus 29 is impossible to find although I have a good stash. I switched over to the silicone oil a couple of years ago and I find it better than Telus 29. You do have to clean the suspension as the silicone oil can creep out of the dash pot.
gold
Post: # 56526Unread post gold
Fri Aug 14, 2020 3:19 pm
I believe the silicone oil specified was Dow Dowsill 510 50cs
