How I suppressed T560 mixer
Iz Carter
Post: # 52199Unread post Iz Carter
Fri Jan 25, 2019 7:20 am
Hi all,
I'm a newbie here and I read a lot of good things on this great forum since a week.
I'm using the T560 since 7 years and it's a very good lathe.
However, I want to add my contribution and share how I removed the mediocre mixer of my T560 Vinyl Recorder.
For this, I'm using Hifi parts that I already have in my studio.
- RIAA pre amp Cambridge CP2
- Headphone amplifier Pro-Ject Head Box SE II
- Passive knob volume
- 3 way audio switch x2
Results : better sound, less background noise, I'm happy :P
Yavor
Re: How I suppressed T560 mixer
Post: # 57549Unread post Yavor
Mon Jan 18, 2021 6:48 am
Hello
Thank you for sharing. I also have a t-560 since 2012 and one of the first improvements was to get rid of the cheap mixer
Best wishes!
summelumsen
Post: # 64039Unread post summelumsen
Mon Jan 29, 2024 2:00 am
Hi - Im pretty new to cutting and i just got the t-560 and im in doubt about the signal chain. Maybe you can help me?.
The doubt i have is if the vinyl optimizer should be before or after the (19" Main Unit with,RIAA encoder, Groove controller, Stylus heating regulation) before it goes on to the cutteramp.
Thanx in advance.
David34
Post: # 64041Unread post David34
Mon Jan 29, 2024 4:09 am
I changed to Mackie Big Knob (older version
With phono) and my cuts are the loudest and cleanest ever!
Bye bye red lining Souri mixer!
Post: # 64085Unread post tragwag
Thu Feb 01, 2024 4:53 pm
yeah toss the mixer and the vinyl optimizer, do it in the box.
I go audio interface -> meter -> amp -> head
duffledub
Post: # 65009Unread post duffledub
Mon Jun 03, 2024 9:04 pm
David34
Hi David, how did you route your system using big knob?
Can you lay out?
Thank
