CD Centre Hole Adapters?
When cutting on cd's what do you use as the inserts to play on a record player?
Any links would be great
Re: CD inserts
I know Mike PIAPTK has made his own, they work great and look snazzy.
http://piaptk.limitedrun.com/products/535023-cd-record-series-digital-analog-hybrid-discs
I've just glued or taped 45 RPM punchouts to the center, not elegant at all but gets the job done.
- Fela Borbone
Re: CD inserts
I use a m8 , filing a little inside and thermoshrink tube around....
Re: CD inserts
The 45 punch out is a great idea, I'll head along to a plumbing supplier and see what they hsve
Re: CD Centre Hole Adapters?
i cut a 46 mm (in diameter) circle with a 7 mm centre hole out of card board (or thick magazin covers ...) and glue them onto the CD
for recording:
i use a 15 mm (in diameter) plastic round bar with a drilled centre hole (7,3 mm)
Hi There,
Has anyone had any joy with these 45 RPM Jukebox Record Dinkers + Centres or would they remove too much material and crack the C.Ds.?? Just a thought, they maybe worth considering eh?
Soulbear
![Wink :wink:](./images/smilies/icon_wink.gif)
![Razz :P](./images/smilies/icon_razz.gif)
Pretty sure that dinker is only for UK 45s like pictured below. I believe it breaks the center out and doesn't actually cut. I don't think it has a blade and even if it did, the poly being so brittle it would break the CDs every time.
![Image](http://www.feelnumb.com/wp-content/uploads/2012/10/The-Beatles-Love-Me-Do-P.S.-I-Love-You_single_parlophone_1962.jpg)
Hi There,
Oh yes, I now clearly see what you mean (Shoulda Looked a little Closer perhaps, Oops), I'd never seen one of these gizmos in action, and I didn't realise they are not a cutter as such. Another thought was using a Hole Saw but again I guess the CDs would be quite difficult to hold securely while making the cutout. Scope in the marketplace for a CD Modification Gizmo I think, as a quick glance at the many videos on the tube seem to indicate that CDs are an often used media for experimenters and experienced cutters alike. MMMmm??Te He
- Fela Borbone
Maybe this?....
If the cd hole is cut out won't it work in CD players and loss the cd/record thing
- yourbedhead
allex_rex
where did you get the round bar?
alex rex wrote:for playback i do this:
for recording:
I have a bunch that I had custom made. They are $.25 each. They are nice, because they are slightly sloped on the side, so they sort of pop in and stay put more or less. email me at lathecuts-a-t-ya-hoo-dawt-cawm
- fredbissnette
