SAL74B POWER SUPPLY BULB
- jtransition
Evening Lathe Trolls
Has anybody got a source for the BA7 bulbs that fit into the power supply on the Neumann 74b Rack,they are rated @240v?
Thanks
Thanks
- Stevie342000
Re: SAL74B POWER SUPPLY BULB
Are you sure it is 240 volts? It should be stamped on the base, I did a quick search on eBay plenty of BA7 bulbs but only up to 24 volt 3 watt.
- jtransition
Yes it is definitely 240v
- Stevie342000
Have you tried Digikey, Farnell, Conrad, RS Components or Allied?
You may find what your are looking for or on the off chance Maplin.
240 Volt is not a regular value you see very often. Try US Ebay you will find it, it may take time or someone here may know of a source.
They will be out there it is just finding them that will be the issue. I am not familiar with it's use or any of the Neumann circuits.
Would it be possible to use a lower voltage type and a dropper resistor? Is the role critical?
