What exactly is a Maselec MDC-70?
fraggle
Post: # 20333Unread post fraggle
Thu Jul 05, 2012 4:36 pm
Is that a pitch controller?
Post: # 20334Unread post opcode66
Thu Jul 05, 2012 5:11 pm
From my understanding it is not a pitch computer. It is more or less a remote control for the VMS. It is also a monitoring mixer and allows you to adjust the levels of your preview signals.
Post: # 20344Unread post mossboss
Fri Jul 06, 2012 1:26 am
The MD70 effecitvelly makes the VMS 70 an 80 with land & depth of cut control as well as the ability to adjust levels with greater ease including more accuracy plus a whole lot of bells and whistles
Due to the fact that these two parameters can be set you get about 10% extra real estate on the record
Another function it has is that the meters are "corected" for any meter offset that happens as well as the ability to set a cutting level by playing a test or any record that one wants to match the cutting level to
In my view a very expensive option but a very good system add on all the same if you got the dough to throw at it or sell your 70 and get an 80 for a lot less That is if you can find one of course
Never seen a used one for sale either so whoever has them they seem to keep them
I often wonder how many are out there in evereday use, any clues???
fraggle
Post: # 20345Unread post fraggle
Fri Jul 06, 2012 4:13 am
Thanks for the info mossy.
You can get it brand new.
https://proaudiogear.de/product_info.php?products_id=685
you can also get it for the vms80...
Post: # 20350Unread post opcode66
Fri Jul 06, 2012 12:05 pm
mossboss wrote:Due to the fact that these two parameters can be set you get about 10% extra real estate on the record
Isn't that what the trimmer pots on the PS66 are for???
gold
Post: # 20353Unread post gold
Fri Jul 06, 2012 1:39 pm
opcode66 wrote: Isn't that what the trimmer pots on the PS66 are for???
Most cutting consoles had Preview Offset. This is more convenient and more repeatable than tweaking the programmer. The MDS-70 also has Preview Offset in sum/difference as well as L/R which is very handy.
The MDS-70 is a companion piece to the MTC-2 console. It doesn't make sense to operate it as a standalone unit.
