vacuum pump vms70
vacuum pump vms70
hi guys,
in stead of a "real" pump my vms70 came with a vacuum cleaner which works well i assume (currently assembling the lathe) but it makes a hella lot of noise so im looking for a replacement pump. now i found this pump online and was wondering if its powerfull enough:
Type: suctioncompressor, oilfree
Motor: 1/5 hp (150 Watt)
1450 / 1700 rpm
Standardvolume: 20 - 23 L/min
Max. pressure: 7,0 bar
Max. Vacüum: 600 mm Hg
Hoseconnect: 1/8" 9,7 mm
Noise: ca. 40 dB
any help or suggestions appreciated.
1450 / 1700 rpm
Noise: ca. 40 dB
My vaccuum is a modern replacement for the original. I will find out the source and try to get a model number for you.
Mine is encased in a wooden enclosure that dampens the noise. Not sure if the enclosure is original or custom made. I put it on a folded towel and that keeps it from transferring the noise through the floor.
here's a link to the one i found:
http://www.webprodie.nl/admin/user/webshop/webshop_show_product.php?productID=255378
Size: 255 x 135 x 170 mm
- Aussie0zborn
I would say that would work. It was not uncommon to use a vacuum cleaner as a replacement. You can run the vacuum cleaner off a 110 volt step-down transformer to reduce the noise (and the suction). You can also place the vacuum cleaner in another room to reduce the noise it makes.
First thing is to get the lathe up and running.
no problem...but its all in dutch though.
http://www.internetwebshop.nl/webshop/bekijk_product/255378/Airbrush_mini_compressor_en_vacuumpomp_in_1.html
- concretecowboy71
- concretecowboy71
Here is the original thread:
https://lathetrolls.com/viewtopic.php?t=1778&highlight=vacuum&mforum=lathetrolls
Thanks Misjah - no problem with translating.
Just need enough Dutch to be able to Google it!
Here's the same model in the UK:
http://www.amazon.co.uk/Airbrush-Mini-Compressor-Vacuum-Pump-device/dp/B0036OGDVC
![Laughing :lol:](./images/smilies/icon_lol.gif)
- theartofmastering
vms70 pump
Hi Misjah,
Strange asking the world when all the answers were sitting beside you in the Van driving the lathe from London to Numansdorp.
Maarten de Boer
The Masters
Emil Berliner Studios
Maarten de Boer
The Masters
real life is analogue
Misjah,
I puchased my lathe restored by Al Grundy. He used this vacuum motor as a replacecment for my lathe. It is enclosed in a wooden box to help with the noise.
I got the shipping box for the motor. This is what is on the label of the box. I believe 2M192 is the model number.
AMETEK
116311-01
2M192
Vacuum Motor
2-Stage, THR BALL BEARING
120 Volts 50/60 HZ
AMETEK
Lamb Electric Div.
Kent, Ohio 44220
USA
Take Care,
Todd
AMETEK
116311-01
2M192
Vacuum Motor
120 Volts 50/60 HZ
AMETEK
Lamb Electric Div.
Kent, Ohio 44220
USA
Take Care,
Todd
- dietrich10
Re: vms70 pump
theartofmastering wrote:Hi Misjah,
Maarten de Boer
The Masters
Because i didnt expect the vacuum to be THAT noisy and i didnt want to bother you on sat/sunday with a vacuumcleaner question. Will call you today though
![Wink ;)](./images/smilies/icon_wink.gif)
http://cgi.ebay.com/ebaymotors/Vacuum-Pump-Rotary-2-CFM-1-6-HP-1720-RPM-R12-R22-R134a-_W0QQcmdZViewItemQQhashZitem5197870f36QQitemZ350434561846QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
what about something like this one.. can't beat the price..
