So - ever since getting to cut sides until 5 years ago at the now closed Europadisk I've been wanting to get a lathe again as I really missed getting to do this. After lurking for a few years on various systems for sale (most that were out of my budget - such as the complete systems being offered by Al Grundy - due to the fact that I refuse to ever go in debt to get audio gear) back in mid October I found a Fairchild 523 lathe on ebay and successfully won the auction.
![Image](http://www.totalsonic.net/fairchild/1.jpg)
I have never seen another one like this - but it's a precursor to their more commonly known 740. It's definitely not as capable as a Neumann - but it's super hefty (in fact looks based on pics to be a good bit heftier than the 740) and has a number of "pro" features such as vacuum lock down on the platter, continuously variable manual pitch (with a full range of 80 - 500lpi via a single feed screw), chip pickup, 16" platter, 3 speed, inside/out and outside/in capable, built in Spencer microscope, and what looks to me like a decently designed overhead carriage system.
Thanks to Oliver Read's excellent book "The Recording and Reproduction of Sound" (available for download as a pdf - along with tons of other great stuff at - http://www.tubebooks.org/technical_books_online.htm ) - which includes a good bit of easily understandable intro on disk recording - I was able to find a few pages of info on my lathe:
http://www.totalsonic.net/fairchild/fairchild523.pdf
Introduced in 1952 - although since mine is 3 speed (and not just 2 speed as described in this article) as well as its higher serial number (#141) I believe this was likely made a few years after this.
I finally took a road trip this past weekend courtesy of my friend Keith who has a mini-van and was extremely generous to help me drive up to Windsor Ontario and bring the lathe back to Brooklyn.
It turns out that the previous owner was Richie Hawtin! (famous among ravers and electronic dance music enthusiasts for his 90's minimalist techno - and more recently for his productions as "Plastikman" - and in fact featured on the cover of this months' EM) - who was using it to cut dub plates for his own DJ sets. Richard has been living in Berlin and touring most of the time - so he stopped using this lathe to make dubplates about 6 years ago, and just had it in storage at his Dad's place in Windsor. His Dad wanted the work shop space back (Richie keeps collecting 80's era arcade games that take up space as well - saw a vintage Pac Man there) and Richie initially told him to "just scrap it." Luckily for me his Dad bothered with putting it up for auction instead!
The drive back home was slightly adventurous in that we got hit with a snow storm in Ohio & Michigan - but luckily my friend grew up in Syracuse NY so was used to driving in this stuff. We made stops in Cleveland the way there and in Clarion PA on the way back - with whiskey and pub& diner food to warm us up at these pit stops. Unfortunately because of the weather we decided to let discretion rule over tourism so didn't get to make a planned stop at the Rock'n'Roll Hall of Fame - but guess I can do this next time I'm ever up there.
The movers got it up the 2 flights of stairs (the building my studio is in was built circa 1900 and has no elevator) without incident except for a scratch on one of the wooden cases sides (not really a big deal as I figure I'm going to eventually repaint it back to something like the original black anyway).
Plugged it in and did a few basic tests a couple days ago. All 3 speeds of the turntable motor are working, motor is reasonably quiet, pitch control and carriage control is working, even the lamps on the microscope and controls are all good.
Turns out this lathe is truly continuously variable pitch (instead of discrete steps that I worried it would be) - so theoretically it could be converted to automatic pitch (although probably really difficult to do - we'll see).
It came with the chip jar and all the hoses to hook this up and for the platter lock down to the vacuum as well - and doing a quick test this with just my regular vacuum cleaner all the connections seemed to work ok. So just need to get a decent vacuum for this (any suggestions on one - especially one that runs relatively quiet - is appreciated!).
This thing has awesome torque too - it kicks in to full speed after about a second - no need to give it a push like you do on the older Neumann's - and you can push your hand hard against it and didn't seem to slow down.
Next up is that I need to add a tonearm and do some tests for wow, flutter, speed accuracy and rumble. Right now the best bang for buck solution I think I've found are the new Rek-O-Kut Transcribe arms for just under $600 - http://www.esotericsound.com/ArmsAndHeadshells.htm (although for $150 more I can get their S-260 MK II arm which includes fluid damping - which should make it able to play more difficult passages as well as minimize high freq resonances more - but don't know whether this is actually desirable on a tone arm which I will likely be checking cuts on more than using for archival transcriptions). If anyone has a tone arm that will work well with the 16" platter that they'll let go for less than this please contact me though!
After that the to next things on the to do list is: most likely building an isolation platform (to completely minimize rumble going to the platter from the floor) and also a vacuum for the platter lock down and chip pickup.
Following that I need to decide on whether to source a Gotham amp to work with the Grampian B1/AGU that is already mounted on this so that I can just get started cutting (which I'm kind of leaning towards right now) -
or to possibly delay this and put this cash instead towards sourcing a stereo head / suspension & mount / and either dedicated stereo cutter amps or just a front end of an RIAA encoder/meters/feedback controller/etc. that I can use with my own stereo amp (i.e. I have a 200 wpc Rotel RB1080 relatively clean solid state power amp just sitting around not being really used at the moment that I could possibly use towards this to get started).
Right now possible options for conversion to stereo cutter head are:
* have Len Horowitz at http://www.hrsrecords.com/ source and restore a Westrex 3D (or if he can locate one - a Haeco SC-2 which might be better for this lathe as the housing is smaller) back to original specs - quoted rate was $2100. I'm leaning towards this in that these are known to be robust and Len is easily accessible if I ever need repairs - but I'm worried with its weight and size that it wouldn't fit on the lathe without serious modifications - and that it might be too heavy for the bearings on the suspension to not end up being worn down really quick.
* try and find an Ortofon DSS 821 or 732. The weight and size of this cutter would probably make it a good bit easier to mount. The 821 would be way preferable as it specs out to being able to handle higher levels than all the other Ortofons - but I still have seen lots of posts that it still is fairly delicate and prone to getting blown out easier than the other cutter heads - and the only one I know of rewinding these is Etec in Denmark - http://www.etec.dk/ortofon-vintage.html - which I've heard is fairly expensive in their services. I know there is one of the classifieds currently - but they're kind of asking crazy money for this - so if I go this route it would have to be for cheaper than their asking of 8k euro!
* go with a Vinylium SC-99 with a VC-200 - http://www.vinylium.ch - which I was quoted at around $6900 - which might mount easier than the Westrex (although again still require me getting a custom mount made).
* wait for Flo to introduce his "Caruso" head - which at last I was quoted $1500 introductory price (including a PCB for the RIAA encoder/feedback controller that I'd have to build into my own chassis) is the least expensive rout - but at this point this is still "vaporware" and is unproven in terms of its actual sound quality.
(side note: I'm not considering a Neumann cutter head because the suspension box takes up such a big space which would make mounting extremely difficult - and because of the usual expense with these)
Any thoughts on which rout to take or if anyone has any of these items for sale are welcome. Also - any documentation on the Grampian B1 and the Fairchild 523 are also very welcome!!
Folks can pm me directly at steve at totalsonic dot net
& finally some more pics below for your perusal:
![Image](http://www.totalsonic.net/fairchild/2.jpg)
![Image](http://www.totalsonic.net/fairchild/3.jpg)
![Image](http://www.totalsonic.net/fairchild/4.jpg)
![Image](http://www.totalsonic.net/fairchild/5.jpg)
![Image](http://www.totalsonic.net/fairchild/6.jpg)
![Image](http://www.totalsonic.net/fairchild/7.jpg)
![Image](http://www.totalsonic.net/fairchild/8.jpg)
![Image](http://www.totalsonic.net/fairchild/9.jpg)
![Image](http://www.totalsonic.net/fairchild/10.jpg)
![Image](http://www.totalsonic.net/fairchild/11.jpg)
Best regards,
Steve Berson
