diamond stylus again:)
- subkontrabob
I think the website says everything:
Synton-MDP is a manufacturer of diamond stylus for metrological equipment (surface finish, profile, form, nano-indentation, hardness, scratch and other characteristics).
But if we look at here: http://www.synton-mdp.ch/en/produkte/Sonderanfertigungen.htm
they can make custum design stylus.
So, I think maybe there is a quite good possibility to make it done.
It would be very nice if You could ask them.
The price, like everywhere, depends on specification of product and of course of a quantity on the order.
Maybe there is some error, but what I saw on the Products menu it cannot be an error. There is nothing suitable for cutting but they showed in a last section that they can do what is ordered. That is the thing we are looking at.
Good luck
Good luck
- subkontrabob
I've worked with a variety of surface science equipment, and if they can do both nanoindentation styli and scratch tester styli, then they probably have the capabilities to do cutting styli for vinyl.
The problem will be with their pricing. Most high end R&D equipment requires precise components, and the users expect to pay for that precision. Unless you can convince their marketing people otherwise, their price models will be much to high.
Who? I am dying for a good, affordable, durable diamond needle that is actually available right now!subkontrabob wrote:Bear in mind we have a man in Switzerland![]()
......and the best part of it is that this company is located only 30 km from his place
- subkontrabob
Diamond Styli
It is in the nature of Humans to live in HOPE
I think a dead horse is flogged on this
It is strictly price/quality
You get what you pay for, yes there are quite a few people out there capable of producing these items
Not an issue Just price
Dealing with the diamond mafia its no fun either, (Hello Flo)
"The Vinyl Truth"
mm... Mossy, you have the reason again
The diamonds mafia..
Expensive prices for diamond cutting styluses, the quality its necessary and immeasurably? (excuseme for my english)
For cutting blanks need a very hi-quality diamond because you have forces in all angles, the sharpened isnt very important, the quality its the problem.
Only good prices for big quantities... but I've been offered straight-cut sapphires, like cut diamonds for 0º cuts, i have been told me they are very hard too if i just want to cut polycarbonate, not for metal cuts (DMM, not heavy metal
You are the Men Mossy
Cheers!
Cheers!
Marcos
Farking Diamonds
Hey All
There will be no such thing as low cost diamonds OK!!!!!
Not possible, even if they are "Blood Diamonds" there will still be a high price for them for the likes of us
"The Vinyl Truth"
The way I see it, we use diamonds for three reasons:
1) having to change a stylus means downtime
2) when it works you do not have to change very often
3) diamond is the best heat-conducting material there is. It is the only efficient way to get the heat from the heating coil to your lacquer surface. So, there is no substitute!
It was much easier in the old days: the cutting needle sat in a chuck and you would change it according to the material you were cutting on. The high linear velocity at 78 rpm made sure you had a clean cut.
This is all tidbits; best wishes ...
I think it depends on what you're trying to accomplish... if you're going for no-maintenance, pro-sound, maybe diamond is the only answer.
If you're experimenting, I think markrob's experiments with lapping high-speed steel might be a more reasonable alternative. If a person could cut a full side with a HSS needle and get good sound, to me, that would be good enough... sharpen it and you're ready to go again. Or make a bunch of 'em and sharpen them as needed.
Aaron
You got it right man that is the way to do it The only issue is that you would need a good jig as well as a good grinder with a diamond wheel not that expensive as a first choice or by hand on a lap as mr robinson does
Alternative scrounge around for a faceting machine used That would be fine may be around the $300-800 mark that is the ultimate really
Use the faceting lap and you can get the right angles as well as a mirror finish on the HSS saphire or even diamonds the last would take time
You can than get some man made or even natural diamonds used recovered from tooling they would be fine for a few cuts You may even get lucky and get an excellent one or two There is a guy selling them on ebay by the carat Pot luck indeed but there would be enough there to get a few out of the bunch I have seen him on ebay quite often and for the qty he offers it is a damn good price They are recovered from dressing tools so they are "pointers" ruined/worn on one side but the other side would be fine More than good enough for the likes of us here non pro use
Food for thought
Food for thought
"The Vinyl Truth"
