I've always been a record fan (got my first record player when I was 7, at a jumble sale), and an enthusiast of various old/retro technology, but the world of lathe cutting records is new to me so I apologies for the silly questions - but I am keen to learn!
My main interest is in film - that is the technology of motion picture photochemical film, mostly the 35mm film used in commercial cinemas as the predominant way to project movies from the late 1800s up until 2014, and still occasionally today for specialist films (such as Chris Nolan's films, Tarantino's films, and more). I have a small 35mm film collection and some film projectors, and I love playing with them and experimenting with this now-obsolete technology.
Film and records do have some crossover, which is why I'm here. About 100 years ago, in the 1920s, the first "sound on disc" movies and equipment was made. For the first talkies, or movies with synchronised music/talking, sound was recorded onto shellac records, which were then played back in synchronisation with the projector, to create image and sound together. The most well known and populate system was Vitaphone, which turns 100 years old later this year, having premiered with Don Juan in 1926.
I'm involved with a group that has lots of vintage movie equipment, including some original sound-on-disc projectors. It would be absolutely lovely to be able to take a modern movie (or even the sound and picture elements of an old one) and create the film picture and Vitaphone record sound disc to run on one of these projectors, to celebrate the 100 years of Vitaphone. Recording image onto film is solved and relatively straightforward, but creating the 16" records is not, which is why I'm here looking for help.
Vitaphone records were a bit special in a few ways:
- First, they use 16" records, not the 10" or 12" standard at the time. This is the same size as some "transcription" records.
- They also run at 33 1/3 rpm, in order to get 10 minutes of playtime from a single disc. 10 minutes is the equivalent of 1 reel of movie film (at the time) so this was used as a requirement for the runtime of the record.
- Vitaphone records also play from the inside to the outside - the reverse of what is normal. This was so that the larger diameter outer grooves would be played last, when the needle would be most worn, in order to get the best fidelity possible out of the recordings.
When doing some research I found a couple of places that have the ability to make a "steel needle compatible 78 record": Duncan at Vulcan Records in the UK, and Custom Vinyl Records in the USA. Both of these look to use a moulding process, where a master is first cut in wax (or similar), and then a mould created, where harder steel-needle compatible records are then made. However, both of these places can only do a 10" max disc, not the 16" I need for Vitaphone, and likely can't do the reversed-spiral groove either.
So I think I have a few options available to me:
- Convert the sound pickup on the Vitaphone projector to a modern lightweight cartridge. This means I no longer need to hunt for steel-needle compatible discs, however means the playback equipment is no longer original, which defeats the point of this. It also doesn't solve the requirement for the 16" or reverse-spiral groove, so not an ideal option.
- Find someone that can make "steel needle" compatible 16" records. Most ideal for me, but most unrealistic, I think. But I would love to be proven wrong!
- Find someone who can make a 16" record wax cut master with standard (non-micro) grooves, ideally in a reverse spiral, that can then be given to Vulcan Records or Custom Vinyl Records, for them to make the mould and steel-needle compatible disc from that. More realistic than option 2., but still not something that most people will be setup to do!
- Make my own lathe that can cut the 16" size of disc, with standard grooves. Make my own wax blanks, and cut it with the reverse spiral, 33 1/3 rpm groove. Give this to Vulcan Records or Custom Vinyl Records, who create the mould and the steel needle compatible disc. Given the implausibility of options 2 and 3 I fear this is the only real option available to me, but also the one that has the biggest learning curve for me! However I have been inspired by excellent builds such as David's/pentlandsound's lathe
Research
- It is quite common here to emboss polycarbonite with a sapphire stylus. This creates a very shallow/small groove, that sometimes has issues playing on a modern record player. Almost certainly no good for a steel-needle compatible master. A more advanced option is to cut polycarbonate with a diamond stylus - this may need to be heated to do the proper cut. This seems better than embossing, but is still really focused on microgrooves only. Heated cutting was never done on 78s [source].
- For 78s, a standard groove is needed, which is a 5mil groove, cut with a cutting stylus with a 1.5mil tip [source]. Playback is done with a 3mil stylus. On regular 78s, there would be between 88 and 112 grooves per inch, resulting in 3-4 mins on a 10" record [source]. On transcription 78s, there could be up to 120-136 grooves per inch, resulting in a longer playback time, but reduced fidelity. Some rough measuring and napkin maths have showed me that Vitaphone discs used the same 88-112 grooves per inch as regular 78s. They got the extended playback time from the 16" diameter, and the 33 1/3 rpm speed.
- A few years ago lacquer blanks were sometimes used, but with the demise of Apollo Masters in 2020, this is no longer available to anyone but the big labels. These were historically used for standard groove as well as microgroove, so would have been suitable here if I could obtain or make a 16" one.
- Making your own lacquer blanks is something that has been discussed here before, but I don't think I've ever read anyone doing it successfully or a proper guide on how one should do it. There are also some dangers associated with the materials used for the lacquer.
- For 78s (and the Vitaphone discs), originally beeswax was used, which is still readily available today, and seems easier to work with, but has a poorer audio reproduction quality. However I am yet to see anyone discuss much about this, or report results. Obviously a form of this is possible, as it was done back in the day, and Vulcan Records state that their process is to "cut a wax master disc which is used to produce a mould", but they don't say what wax they use, or the process of creating the blanks is.
- Can anyone create a 16" wax/lacquer master with standard grooves today? I would love it to be true, but am not too hopeful.
- The use of beeswax or other similar wax seems my only option today, and has a (slightly dubious) bonus of being historically accurate. Has anyone done created blanks with this? Any advice? Anything from thickness to viscosity and more!
- Does anyone have a 78" standard groove cutter head that they may be willing to sell? Or advice on making my own? I have looked at countless DIY cutting heads for microgrooves and vinyl recently, but am not sure how it is different to standard grooves cutting in lacquer and wax.
- Where can I get standard groove cutting stylii? There seems to be some old threads that discuss their availability, and have people offering to sell them, but nothing I can find today. I'm not even sure what was originally used for 78s/standard groove - was it sapphire?
- If was able to obtain a standard groove cutting stylii, does anyone have any advice on driving it? How do the groove vibrations differ from a microgroove? Would I need to increase the amplification of the driver? Or is that left the same and it's just the groove itself that increases, not the vibrations? What sort of tracking force is needed for these? Does it depend on the material of the wax/lacquer blank?
David
