broken heating wire on stylus fix ?? souri's T560
Handcutzvinyl
Post: # 66602Unread post Handcutzvinyl
Mon Jan 06, 2025 6:05 am
hey yall'S how are ya?
one of the two heating wires of the stylus on souris vinylrecorder just came off. does anyone know the material its made of and what solder to use to fix it?
any recommendations?
greetings!
spinnertownblanks
Re: broken heating wire on stylus fix ?? souri's T560
Post: # 66609Unread post spinnertownblanks
Tue Jan 07, 2025 9:33 am
You can use Nichrome wire, as low as 0.2mm, no need for glue, you can simply wind it around the diamond. The biggest problem is removing the glue that is already there, be very, very careful doing that
www.spinnertownblanks.com
David34
Post: # 66743Unread post David34
Tue Jan 28, 2025 11:01 pm
Send back to Souri. He will fix it for you.
