Wilcox Gaye Recordio- cutting into transparent discs
mike823
Post: # 65451Unread post mike823
Mon Jul 29, 2024 3:05 pm
Hi All,
I'm new to the list. I can cut using recordio discs but only get scatchy sounds when I try to cut blank transparent discs. How do I heat the discs to allow for a cut? I tried a hair dryer, no luck. Suggestions? mike823
lucca2
Re: Wilcox Gaye Recordio- cutting into transparent discs
Post: # 65466Unread post lucca2
Wed Jul 31, 2024 4:22 pm
Hi Mike,
What material are the blank discs?
What lathe are you using? And with what needle?
Cheers,
Lucca
mike823
Post: # 65472Unread post mike823
Thu Aug 01, 2024 10:08 am
Here are images of the cutter and discs
Mike
Post: # 65474Unread post tragwag
Thu Aug 01, 2024 1:54 pm
ok so there are two types of cutting at this level, cutting and embossing.
embossing works with an extreme 'leaned back' angle, which the recordio (I think you actually have a Recordette), unfortunately can't achieve.
so let's put embossing aside, if you'd like to read into it there are many more resources on this forum.
the Recordio/Recordette was built to cut into lacquers or soft coated blanks.
steel or ruby needles were used for this purpose.
the blanks you have there are PETG plastic, much harder than the soft lacquer blanks.
keeping the angle and working relationship of the Cutting process, you would need a diamond stylus to properly cut a groove into those PETG blanks.
I hope this clarification helps, there are resources all over the site as to how to cut vs how to emboss.
The truth is the Recordette doesn't have any adjustments at all, so you're stuck with cutting at one force and angle, and should plan around that.
happy cutting!
