cut half speed if this is where you're going.subkontrabob wrote:Hi, I suspect it would be possible to improve quality by cutting "backwards", because:
- influence of voice coil inductance on transients is decreased
- influence of inertia on the moving parts is turned to benefit
- more accurate signal tracking
- increased thermal performance because heat builds up slower -> system has more time to dissipate it
i would add antoher disadvantage:
recently i had a cut with a 10+ min track of just backwards piano. it was cool but i can't see myself cutting every program backwards unless i'd do it in mute.
do you really see yourself cutting records backwards?
make poll,
